Products
  • Photo of Netro SPARK 1
  • Photo of Netro SPARK 2
  • Photo of Netro SPARK 3
Spark-8, Smart Watering Controller (EU)
List Price:
$179.00
Price:
$99.99
You Save:
$79.01
Model:
Power Adapter:
Works in Germany, France, Italy, Spain, Portugal (and many other European countries), Israel, Brazil and Chile
In Stock
Shipping Policy
Quantity
Introducing Spark
Spark is Netro's new smart watering controller with improvements over the highly rated Sprite in every aspect. It comes with a unique folding design, physical user interface, faster WiFi communication and massive 16-zone capacity. It is enhanced for better local control while retaining all the remote capabilities and smart features.
Touch Control
Now you can start or stop watering through the convenient touch buttons when you are away from your phone or when WiFi is unavailable. Just select the zones, set the minutes and start watering.
LED Display
The backlighting LED matrix shows the active zone and the watering duration. A dedicated colorful LED indicates the connection status and network activities.
Valve Diagnosis (Beta)
Onboard current and voltage evaluation circuit detects faulty solenoids realtime and automatically analyzes the possible causes of the failure.
Backup Program
When WiFi connection is unavailable or having an issue, the backup program stored locally will take over and keep the plants watered
Even Smarter
EPA WaterSense certified. Alexa and Google Home compatible. IFTTT connected. AccuWeather and Wunderground PWS integrated. Spark is born for the IoT world.
Mechanical Specifications – Dimensions: 5.7 X 5.7 X 1.6 (inches) – Weight: 12.7 oz / 360 g – Output: 8 zones + 1 master valve – Wire size: 18 AWG to 22 AWG – Operating temperature: -4 to 122℉ / -20 to 50℃ – Box contains: smart irrigation controller, AC adapter, wall screws, quick installation guide Electrical Specifications – AC Input: 24VAC, 50/60Hz, 800mA – Valve output: 24VAC, 50 / 60Hz, max 10VA – Master valve: 24VAC, 50 / 60HZ, max 10VA – WiFi: 802.11 N, 2.4Ghz, EU Warranty – 2-year limited hardware warranty
user_manual_spark.pdf
The Netro app is capable of managing multiple controllers. You can link two controllers together. You will need to have at least two “common” wires so that each controller gets one. If there is only one “common” wire, it needs to be connected to both controllers by using a wire splitter. It is recommended to only use one power adapter for both controllers. Here is an article to show the connections: https://www.netrohome.com/forum/posts/563
Wi-Fi Connection
Cloud Services
Watering Schedules
Yes. There are three ways to create a schedule: 1) Enable smart zone for automatic schedules (weather based) 2) Add user programs for fixed schedule (cycle based), for example, once every 5 days or every Tuesday and Friday 3) Manually turn on and off the sprinkler using the remote control feature
Weather Data
Watering Regulations
Sensors
Overall rating: 5/5
2023-07-11 13:44:45 UTC
Fully satisfied ! May be the weather forecast could be better
Overall rating: 5/5
2021-04-27 13:21:49 UTC
Can't think of a better smart watering controller ! works flawlessly , setup is a breeze, stats provided are great, the community is amazing, works in Greece too. Can't rate highly enough!
Overall rating: 5/5
2021-04-01 11:15:17 UTC
I request the cancellation of the order, according to the revived mail. in which I have been given a discount code indicating that I cancel and request again. Thanks a lot. You can confirm the process for me. Nicholas.
