Products
Smart Sprinkler Controller
Sprite
Spark
Smart Indoor Watering System
Stream
Smart Plant Sensor
Smart Hose Faucet Timer
Pixie Z1
Pixie
Pixie 2nd Gen
Smart Garden Light
Lapland S1
App
Accessories
Spark-16, Smart Watering Controller
List Price:
Price:
$129.99
You Save:
$69.01
Model:
Power Adapter:
In Stock
Mechanical Specifications
– Dimensions: 5.7 X 5.7 X 1.6 (inches)
– Weight: 12.7 oz / 360 g
– Output: 16 zones + 1 master valve
– Wire size: 18 AWG to 22 AWG
– Box contains: smart irrigation controller, AC adapter, wall screws, quick installation guide
Electrical Specifications
– AC Input: 24VAC, 50/60Hz, 800mA
– WiFi: 802.11 N, 2.4Ghz, US
Warranty
user_manual_spark.pdf
Wi-Fi Connection
Cloud Services
Watering Schedules
Weather Data
Watering Regulations
Sensors
Giovanni Baroni
Member since 2023-03-20
Overall rating: 5/5
2023-07-11 13:44:45 UTC
Fully satisfied ! May be the weather forecast could be better
panos
Member since 2021-01-18
Overall rating: 5/5
2021-04-27 13:21:49 UTC
Can't think of a better smart watering controller ! works flawlessly , setup is a breeze, stats provided are great, the community is amazing, works in Greece too. Can't rate highly enough!
Nicolás De las Heras Ortiz
Member since 2021-03-30
Overall rating: 5/5
2021-04-01 11:15:17 UTC
I request the cancellation of the order, according to the revived mail. in which I have been given a discount code indicating that I cancel and request again. Thanks a lot. You can confirm the process for me. Nicholas.
