Sprinklers don’t work
Richard Mundy
更新時間 2020-05-02 18:59:26 UTC
Please help
瀏覽: 4666   回覆: 1
Carlo Monico
更新時間 2020-04-26 06:59:36 UTC
Grazie.
瀏覽: 4274   回覆: 1
Plant Sensor
Ntenaive
更新時間 2020-04-25 21:56:51 UTC
瀏覽: 4736   回覆: 2
Gian Piero Pepino
更新時間 2020-04-25 09:23:06 UTC
Gian Piero
瀏覽: 4358   回覆: 1
Best sync option?
jbart65
更新時間 2020-04-22 02:56:17 UTC
瀏覽: 4416   回覆: 1
google home not connected
maxtrash
更新時間 2020-04-21 23:01:57 UTC
what could be going on?
瀏覽: 4344   回覆: 2
Keep Connected option
jbart65
更新時間 2020-04-17 17:38:10 UTC
The particulars:
瀏覽: 4395   回覆: 1
Which Alexa app?
jbart65
更新時間 2020-04-16 20:00:55 UTC
Jeffry
瀏覽: 4430   回覆: 1
Netro app on google home
Danilo
更新時間 2020-04-11 10:07:58 UTC
Thanks for your support.
瀏覽: 4318   回覆: 1
Settings
Massimo Povolo
更新時間 2020-04-07 06:31:48 UTC
瀏覽: 4940   回覆: 5
Home Assistant integration
Casey S
更新時間 2020-04-05 19:46:53 UTC
瀏覽: 4881   回覆: 2
duerson
更新時間 2020-03-27 20:59:20 UTC
瀏覽: 4527   回覆: 1
Delivering term please
yodiego
更新時間 2020-03-14 18:08:21 UTC
瀏覽: 4173   回覆: 1
alexa & pixie
stefano banfi gaslini
更新時間 2020-03-11 14:30:37 UTC
hi,
TNKS
best regards
stefano
瀏覽: 4353   回覆: 1
更新時間 2020-02-28 07:49:20 UTC
瀏覽: 6393   評論: 3
Changing ownership of home
Dario Sindicich
更新時間 2020-02-14 01:48:40 UTC
瀏覽: 5104   回覆: 2
Robert Bayes
更新時間 2020-02-07 03:39:19 UTC
瀏覽: 4128   回覆: 1
Introducing the Referral Program
更新時間 2019-12-10 03:02:22 UTC
To the Netro community:
We are pleased to launch the Netro Referral Program. You can earn reward points when your friends become Netro customers!
1.Invite your friends to join Netro using your unique link
2.Your friends get a discount or reward points
Your friends enjoy 10% off their first orders or $10 credits toward their first subscriptions.
3.Get your reward points and repeat to earn more
You will earn reward points* equivalent in value to the discounts or credits given to your friends.
*Reward points: for every US dollar your friends spend on their first orders you will earn 10 points ($0.1). You will earn 1000 points ($10) for every friend who chooses to subscribe. There are 3 ways to redeem the reward points:
1. Use the reward points to purchase Netro products at netrohome.com (100 points = 1 US dollar)
2. Use the reward points to pay for your subscription fee at netrohome.com (100 points = 1 US dollar)
3. Withdraw the reward points to your PayPal account (200 points = 1 US dollar)
Your reward points will never expire.
You can check more info about Netro's Referral Program here https://netrohome.com/shop/refer
瀏覽: 5454   回覆: 2
Raining but still watering
Liaqat Khan
更新時間 2019-12-08 00:23:51 UTC
瀏覽: 4360   回覆: 1
Manuel Roca
更新時間 2019-11-22 17:20:29 UTC
This is an easy question
瀏覽: 4767   回覆: 2
