Internet down
更新时间 2021-07-18 11:38:25 UTC
浏览: 3398   回复: 2
Addiel Isaac Moldes
更新时间 2021-07-18 12:42:37 UTC
It was or wasn't included?
浏览: 3327   回复: 1
Default view on startup
Addiel Isaac Moldes
更新时间 2021-07-18 12:45:53 UTC
浏览: 3187   回复: 1
wwhitfill
更新时间 2021-07-18 13:52:07 UTC
浏览: 3231   回复: 2
Barry Litinsky
更新时间 2021-07-18 23:12:56 UTC
浏览: 3006   回复: 1
Pixie and Whisperer
Nick Thoman
更新时间 2021-07-19 17:46:37 UTC
浏览: 3296   回复: 1
Ramón Rivero
更新时间 2021-07-20 08:32:53 UTC
浏览: 3112   回复: 1
Not all zones are executing
Brian Brun
更新时间 2021-07-20 14:19:47 UTC
浏览: 3484   回复: 1
BaiPhillips
更新时间 2021-07-20 20:42:15 UTC
浏览: 3225   回复: 2
New lawn setting
更新时间 2021-07-21 01:54:26 UTC
浏览: 3407   回复: 1
Netro Pixie with Google Home
fauxserious
更新时间 2021-07-21 19:50:41 UTC
What is the issue?
浏览: 3360   回复: 1
Two electro valves activated at same time
Francesc Rodríguez
更新时间 2021-07-21 20:07:01 UTC
Why is not possible two valves operating at the same time if the pump can be operate correctly?
浏览: 3529   回复: 1
Connect to a network
James Yates
更新时间 2021-07-22 21:08:14 UTC
浏览: 2882   回复: 1
Keep Online
bechard
更新时间 2021-07-24 11:09:25 UTC
浏览: 2838   回复: 0
Strange Whisperer Acrtivity
更新时间 2021-07-24 17:00:16 UTC
浏览: 4032   回复: 5
Eric
更新时间 2021-07-25 05:56:52 UTC
浏览: 2908   回复: 1
Installing New Netro-6
Debby Plenert
更新时间 2021-07-25 14:37:04 UTC
I removed an older controller and replicated the wiring when installing the new Netro.  Everything appears to be correct?  However, when watering is activated, the valves will fill up and vibrate or what not with water rushing internally.  But the sprinkler heads don’t pop up and no water comes out.  Any help here would be greatly appreciated.  Thanks!
浏览: 3741   回复: 1
Rain sensor
更新时间 2021-07-26 12:13:34 UTC
浏览: 3469   回复: 1
更新时间 2021-07-26 16:02:28 UTC
浏览: 3534   回复: 2
David Farries
更新时间 2021-07-28 02:11:18 UTC
浏览: 3420   回复: 1
