Moisture all day
Shai Amiel
更新时间 2021-07-29 03:30:05 UTC
With smart schedule on, sometimes I see "moisture all day" sign to some zones.
What does it mean and what do the application do?
Shai
浏览: 3241   回复: 1
no wifi connection mqtt blocked
更新时间 2021-07-30 18:16:05 UTC
i received Netro programmer
no connection
i have a fritbox 7560
the server status message says
mqtt blocked port 1883
浏览: 3936   回复: 1
Paco Gómez
更新时间 2021-08-01 05:26:03 UTC
Un saludo
浏览: 2804   回复: 1
Data out of the API
Jens Wymeersch
更新时间 2021-08-01 13:24:46 UTC
Dear Netro,
浏览: 3339   回复: 2
Just setup metro pixie.
mprtjd
更新时间 2021-08-01 18:26:34 UTC
浏览: 3116   回复: 2
Brian Brun
更新时间 2021-08-03 02:40:17 UTC
浏览: 3243   回复: 1
Weather Provider Error
Jacques
更新时间 2021-08-03 22:26:44 UTC
浏览: 3454   回复: 2
One zone not working
S Yarrish
更新时间 2021-08-06 00:50:19 UTC
浏览: 3166   回复: 1
Francesco G
更新时间 2021-08-08 17:24:19 UTC
浏览: 2937   回复: 1
Moisture
cirujanoramirez
更新时间 2021-08-11 12:38:30 UTC
浏览: 2949   回复: 1
Google Home
Michael Wheatley
更新时间 2021-08-11 15:45:28 UTC
浏览: 3131   回复: 1
Skip zone
the2brads
更新时间 2021-08-11 22:21:07 UTC
浏览: 2981   回复: 1
access to data
更新时间 2021-08-14 15:46:27 UTC
浏览: 3336   回复: 1
Sensor doesn’t work correctly
Paolo Sciarappa
更新时间 2021-08-14 20:06:25 UTC
The graphic is very poor.
 Any suggestion.
Thanks Paolo
浏览: 3207   回复: 1
Adaptador
Roberto Baltar
更新时间 2021-08-16 05:47:49 UTC
Hola.
浏览: 2999   回复: 2
% moisture
Julie Huynh
更新时间 2021-08-17 15:09:16 UTC
浏览: 3949   回复: 2
Daniel Encinas
更新时间 2021-08-18 06:17:45 UTC
Hi all,
Thanks a lot,
Daniel
浏览: 3288   回复: 1
Insertar programss
Gaspar Morey
更新时间 2021-08-20 20:01:36 UTC
浏览: 2766   回复: 1
javier58
更新时间 2021-08-21 02:52:17 UTC
浏览: 2792   回复: 1
Michael Gough
更新时间 2021-08-21 14:21:39 UTC
浏览: 3246   回复: 1
