Douglas Peale
更新时间 2021-05-28 02:59:54 UTC
浏览: 3181   回复: 1
更新时间 2021-05-28 19:17:48 UTC
浏览: 3613   回复: 1
Pedro Abad
更新时间 2021-05-30 08:18:01 UTC
Thanks and best regards
浏览: 3283   回复: 1
Pedro Abad
更新时间 2021-05-30 08:33:28 UTC
Thank you all!
浏览: 3371   回复: 2
Wisperer not working
Andrea Paparotti
更新时间 2021-05-31 14:42:20 UTC
浏览: 3530   回复: 2
Yuriy Andamasov
更新时间 2021-05-31 19:44:41 UTC
Thanks in advance.
浏览: 3132   回复: 1
Completely ater
更新时间 2021-05-31 20:03:22 UTC
浏览: 3255   回复: 1
Wi-Fi connectivity
saketshah
更新时间 2021-05-31 21:20:22 UTC
Appreciate your help.
浏览: 3227   回复: 1
Sign it
Matthew Gruen
更新时间 2021-06-01 00:50:47 UTC
浏览: 3263   回复: 1
Mancata irrigazione
Cristian Toraldo
更新时间 2021-06-01 05:47:43 UTC
Buongiorno ogni volta che salta la corrente la centralina crede di funzionare ma gli irrigatori non partono. Per far sì che tutto riprenda a funzionare bisogna ogni volta resettare la centralina ma se qualcuno è via per molto tempo potrebbe costituire un grosso problema.
浏览: 3132   回复: 1
UK watering restrictions
更新时间 2021-06-01 11:26:19 UTC
Cheers,
Andy
浏览: 4603   回复: 1
Sensor inputs
更新时间 2021-06-01 11:33:16 UTC
浏览: 3307   回复: 1
60 minute limit
C S
更新时间 2021-06-01 21:33:39 UTC
浏览: 3048   回复: 1
sal.jamil@me.com
更新时间 2021-06-02 12:11:24 UTC
浏览: 3164   回复: 1
Moisture level correction
更新时间 2021-06-02 21:51:35 UTC
浏览: 3563   回复: 3
Weather
Gianluca De Virgilio
更新时间 2021-06-03 14:47:01 UTC
Good afternoon,
浏览: 3375   回复: 1
Manual Watering
Kevin Westling
更新时间 2021-06-04 00:42:16 UTC
浏览: 3241   回复: 1
Best time for irrigating
更新时间 2021-06-04 19:44:57 UTC
Late in the night, 21, 22.h
Thx
浏览: 3666   回复: 2
Schedule stopped working
更新时间 2021-06-04 20:37:36 UTC
浏览: 3457   回复: 1
beta tester
更新时间 2021-06-06 07:50:32 UTC
浏览: 3423   回复: 1
