Whisperer stop working
Gianluca De Virgilio
更新时间 2021-05-11 15:34:15 UTC
Ideas?
浏览: 3307   回复: 1
Smart water regulation
Albert Heinold
更新时间 2021-05-13 09:40:49 UTC
Thanks for any help.
浏览: 3021   回复: 1
Whisper Pairing
Sang Peiris
更新时间 2021-05-13 12:11:59 UTC
Hello-  I have two new whisper devices. Both will not go into pairing mode.  Press power button six times and the light just blinks red on and quickly off. Press three times and same thing.
How do I get the whisper into pairing mode?
浏览: 3459   回复: 1
Rainfall from weather station
更新时间 2021-05-14 16:50:13 UTC
浏览: 3372   回复: 1
John Lillistone
更新时间 2021-05-15 09:23:08 UTC
Any ideas anyone?
浏览: 3183   回复: 2
Watarering modes
更新时间 2021-05-16 07:44:57 UTC
Hi there
浏览: 3641   回复: 2
Seed watering
Adrian Azzopardi
更新时间 2021-05-16 10:18:05 UTC
浏览: 3149   回复: 1
Turning off wayer
更新时间 2021-05-16 21:29:12 UTC
浏览: 3460   回复: 2
Programs Setup
fernando colon
更新时间 2021-05-18 04:44:56 UTC
I have 5 zones programmed daily in 15/20/35 mins intervals however when I goto the home screen I see them all in 15mins intervals... Seems as the home screen bypass' the current daily programmed schedule.  How do I have my programs run as intended 15/20/35 .ins intervals vs the 15mins it self imposed?
浏览: 3555   回复: 1
Whisperer connexion
更新时间 2021-05-19 14:52:55 UTC
浏览: 3740   回复: 2
amagalla
更新时间 2021-05-19 16:45:52 UTC
Edit:
The app on my tablet shows:
Server Status:    OK
Response time:  0.3 s
浏览: 3969   回复: 2
bad wireless?
amagalla
更新时间 2021-05-19 16:50:44 UTC
Tony
浏览: 3246   回复: 1
Netro Pixie Timer
claudinne
更新时间 2021-05-20 17:09:36 UTC
浏览: 3258   回复: 1
Mitch Green
更新时间 2021-05-20 22:11:37 UTC
浏览: 3325   回复: 1
Learning
John Conley
更新时间 2021-05-21 12:05:43 UTC
浏览: 3106   回复: 1
Sensor usage
Ilya Lifshits
更新时间 2021-05-22 08:17:29 UTC
Hi ,
Ilya
浏览: 3146   回复: 1
Brad Grizzly
更新时间 2021-05-23 03:42:20 UTC
浏览: 3023   回复: 1
Connect one whisperer to two pixies
jmkluft
更新时间 2021-05-24 14:14:03 UTC
For the moment, I have one whisperer connected to one pixie, and everything is working fine.
I have a question though, if I would add another pixie to control another watering zone, can I connect the same whisperer to that second pixie?
In other words, can I connect one whisperer to two pixies?
Thx,
JM
浏览: 3359   回复: 1
banaszar
更新时间 2021-05-25 17:23:58 UTC
浏览: 3059   回复: 2
Douglas Peale
更新时间 2021-05-27 22:32:59 UTC
浏览: 3230   回复: 1
