Metro timer
Anne McNamara
更新时间 2024-07-04 13:16:31 UTC
Everything shows it should be running, but it doesn’t wake up. I have it set for online during watering periods. It says it’s communicating but it’s not running. How do I wake up metro when I want to communicate
浏览: 7362   回复: 1
Red dot
更新时间 2024-07-03 18:53:21 UTC
What is the significance of a red dot next to the green bell ?
Do not see anything anywhere and have not received any notice.
浏览: 7412   回复: 1
Start two Zones at the same time
Timmmee
更新时间 2024-06-22 18:15:57 UTC
Dear netro team,
I missing the function that I can open two zones at the same time.  If this is possible you could combine different valves.
This would be a huge advantage.
Thanks for your response.
浏览: 7180   回复: 1
Netro Sprite offline
David Domingues
更新时间 2024-06-20 06:58:04 UTC
Since 2 days now, my netro Sprite is offline.
The light is solid  but quickly blinks each 6 seconds.
What should I do?
Are Netro servers online?
David.
浏览: 7496   回复: 1
Weatherflow Tempest PWS Weather Provider
cseward
更新时间 2024-06-17 19:59:17 UTC
I noticed that Weather Flow PWS was added as a weather provider for Netro and successfully linked my Weather Flow Tempest with my Netro Pixie Z1+Hub+Whisperers.  However I have a few questions:
1) There seems to be no way to remove or change the link to Weatherflow, like selecting another station.  Can you add a way to do that?
2) Since linking to Netro, I have changed the name of my Tempest Device on their platform from the default serial number to a descriptive name, but Netro still shows the old name for the device when I click on it in the Weather Provider menu, is that a problem, or are they still linked?  (and if it is a problem, how can I update the link?)
3) What data is actually pulled from Weatherflow?  The forecast shown in the Netro app does not line up exactly with what my tempest shows, nor do the rainfall totals on the discover tab.
4) I have also linked my Tempest with Weather Underground and can use them as a Weather Provider instead.  The Netro app says Weatheflow PWS shares 9 days of forecast and 1 day of history, while Wunderground PWS shares 7 days of forecast and 7 days of history.  I prefer not relying on an additional middleman to link my tempest to Netro, but is it better to have the additional history or additional forecast?
浏览: 7246   回复: 1
Changing order of zones
Sasha Obradovic
更新时间 2024-06-15 02:06:31 UTC
Hello, can you please tell me is there possibility to switch order of zones how they appear in the menu
浏览: 7265   回复: 1
Orario programma intelligente
Mattia Forti
更新时间 2024-06-14 16:13:19 UTC
Salve, imposto in PREFERENZE due cornici di irrigazione.
Dalle 3 alle 9
Dalle 23 alle 24
Il programma intelligente continua ad irrigare alle 18.
Salvata più e più volte questa impostazione di orario ma continua ad irrigare spesso alle 18.
Come risolvere?
浏览: 7386   回复: 1
My New Whisperer 2 doesn't switch on
JDo REY
更新时间 2024-06-12 16:24:26 UTC
My New Whisperer 2, after worthing fine for 2 days connected in the garden, now doesn't switch on any more, even after USB charging (showing full charge green light near the USB socket). It's offline and nothing happens when pushing the power button once, for 3, 5, 10, 25, 30 seconds.
What do you think ?
浏览: 7256   回复: 1
My zone is leaking water even when it’s not running.
kgonzales
更新时间 2024-06-12 03:11:04 UTC
What should I do? Water is leaking out of my zone 5 only when they aren’t being used creating giant puddles in my yard. Any help?
浏览: 7094   回复: 2
Pixie Hose Faucet Timer
Robert Greenwood
更新时间 2024-06-06 22:42:03 UTC
When I put a fully charged battery in the timer, the white light comes on. I press the button to try to link with the WIFI router, nothing happens. I never see a white flashing light. If I press the button again a steady red light comes on. I have another Pixie and it links quickly with the router and works well so I know the WIFI router is working well but it never sees the water timer that is not working.
浏览: 7369   回复: 1
Water timer pixie
Anne McNamara
更新时间 2024-06-06 19:53:04 UTC
How do I lengthen the duration from 60 minutes to longer
浏览: 7357   回复: 1
Problem with flow interruption
Giuseppe Natilli
更新时间 2024-06-04 16:13:25 UTC
irrigation programs don't stop. even if the timer stops, the water continues to flow out. even if active in manual mode, I can't stop the water flow.
浏览: 7457   回复: 1
Mutiple Zone runing at the same time and half the zone (6-12) not actually running
harrywhl
更新时间 2024-06-01 23:57:27 UTC
My Netro-12 is currently running 5 zones at the same time when it was mannually turned on to go each zone at a time, also, the back end of the zones (6-12) does not respond to the app commands and whenever the app said the zones were turned on, it was still the first five zones that were running.
浏览: 7111   回复: 1
Cant connect
B Ray
更新时间 2024-06-01 22:41:52 UTC
How close does this pixie z1 faucet timer have to be to the hub because it’s approximately 21 ft from it…
WiFi connected
Hub light is solid green
And the timer is offline
Won’t stay connected
浏览: 7162   回复: 1
Two times zone watering
Jerry Agresti
更新时间 2024-05-30 17:03:18 UTC
Hi there. How can I program specific zones to water twice in one day?
浏览: 7097   回复: 1
Invalid group ID 39654: invalid device status - shows in the app
Ashok Vengidapathy
更新时间 2024-05-28 05:22:36 UTC
I am getting an error in the app like " Invalid group ID 39654: invalid device status "
What would be the reason.  Also I am unbale to pair my device.
Please advise on this.
Ashok.
浏览: 7289   回复: 1
Moving from hunter to netro 12 zones
rabatmaroc
更新时间 2024-05-27 02:50:28 UTC
Hi gents
I have setup a new up to 12 zones metro  replacing an 8 zone hunter system.
So far only 5 zones are active
I am missing something small
Hunter old wiring attached
浏览: 7601   回复: 2
WATER SCHEDULING / WEATHER INFORMATION UPDATE
Javier NM
更新时间 2024-05-26 06:49:27 UTC
First of all, I have been using my Sprite for one year, and the result is very positive. My lawn is better, and I have learnt about how watering should be done in my case. Congratulations to the Netro team. Let me add some questions below.
On 2023-06-13 Wency said "Netro sever side gets/ updates weather information every early morning at around 4 am.
If the weather forecast changes, Netro will update and recalculate the schedule." But could you expand what time zone is this 4 am?.
And a second question is: how often the system recalculates the watering scheduling after a programmed or manual watering? Will that go in the same refreshing as the weather info refreshing? also at 4 am?
浏览: 7511   回复: 1
No Answers
Charles Currie
更新时间 2024-05-25 17:07:13 UTC
浏览: 7167   回复: 1
mae winslow
更新时间 2024-05-24 02:05:23 UTC
浏览: 7105   回复: 1
