Mike Carey
更新时间 2025-03-02 17:48:24 UTC
浏览: 7562   回复: 1
Door came off the unit
Michael Riley
更新时间 2025-02-19 19:52:51 UTC
浏览: 7409   回复: 1
W4MSolutions
更新时间 2025-01-23 17:32:49 UTC
浏览: 7542   回复: 1
Pixie - Z1
Steve Inwood
更新时间 2025-01-16 10:10:53 UTC
浏览: 6905   回复: 1
Trevor Pfeiffer
更新时间 2024-12-26 20:05:12 UTC
Trevor Pfeiffer
浏览: 6982   回复: 1
John BAIMAY
更新时间 2024-12-26 11:35:25 UTC
Regards.
浏览: 6961   回复: 1
Sprite / Spark and Flume
Bruce P
更新时间 2024-12-12 22:28:13 UTC
Thinking of scenarios like:
浏览: 6856   回复: 1
Carolyn Simmons
更新时间 2024-12-01 20:53:00 UTC
浏览: 6965   回复: 1
Andrea DS
更新时间 2024-11-27 21:01:38 UTC
浏览: 7019   回复: 1
Konrad
berlin
更新时间 2024-11-10 09:36:28 UTC
Who can help me?
Thank's
Konrad
浏览: 6700   回复: 1
Conrtoler
John Zuzula
更新时间 2024-10-19 23:45:24 UTC
浏览: 6820   回复: 1
Manual mode without delay
Phil Houghton
更新时间 2024-10-04 23:27:59 UTC
浏览: 6766   回复: 1
How do I?
Rockhead413
更新时间 2024-10-01 00:08:51 UTC
Vincent Devlahovich
805-813-1216
Loyal customer
浏览: 6887   回复: 1
更新时间 2024-09-19 03:30:21 UTC
浏览: 38725   评论: 3
Ac adaptor
Cisco -
更新时间 2024-08-24 21:45:58 UTC
浏览: 6984   回复: 1
Van Klaveren Patrick
更新时间 2024-08-15 10:04:53 UTC
浏览: 7161   回复: 1
Smart watering very stupid
Ruth Wengert
更新时间 2024-08-13 14:22:33 UTC
浏览: 7176   回复: 1
Terminal 1 not working
Morgans_Home
更新时间 2024-08-12 01:27:03 UTC
浏览: 7068   回复: 1
Sensor plat
Tiago Lourenco
更新时间 2024-07-28 12:17:00 UTC
Good afternoon
I have plant sensors in all zones, and they block.
Sometimes i have my grass really dry and the sensor have 70/80 % of humidity.
I turn them off change place like 2 cm, turn them in again and they have the correct humidity.
Anyone experience this?
Thank you in advance
浏览: 7647   回复: 3
Metro timer
Anne McNamara
更新时间 2024-07-04 13:16:31 UTC
Everything shows it should be running, but it doesn’t wake up. I have it set for online during watering periods. It says it’s communicating but it’s not running. How do I wake up metro when I want to communicate
浏览: 7226   回复: 1
