Spark 16 works only in manual
Davide Riva
更新时间 2025-08-11 21:55:04 UTC
Hello, I’ve installed netro app on my iPhone, followed the procedure to connect the spark 16 and everything is fine, but when I try to activate valves with the app, the led turn white.
If I remove spark 16 from the app, the led turn green and I can only activate valves from the controller,
Any solution?
Davide
浏览: 6169   回复: 2
App reports off-line, controller is on-line and web based app is on-line
Jorge Rodrigues
更新时间 2025-08-08 18:46:45 UTC
I have a strange situation:
- App reports controller as off-line, sometimes it reports on-line for brief periods. It was working fine till three days ago
- Controller has green light
- Web app on the netro site reports on-line and works
- The controller is watering
- The Wifi near the controller is working and I have not changed the password or settings
- I have tried forcing it to change the wifi, I get the bluetooth light and the controller is detected on the app via bluetooth, however it fails after I insert the password for the wifi. This is odd since the device is connected.
I suspect there is a synch issue between the App and your servers. Help would be appreciated.
浏览: 3540   回复: 1
Spark not working – won’t start valves despite all attempts
Stefano
更新时间 2025-07-23 06:55:23 UTC
Hi everyone,
I’ve been using a Netro Spark (8-zone model) for some time, but recently it stopped working properly.
The controller connects to Wi-Fi and appears online in the app, but when I try to start any valve (manually or via schedule), it says “communicating” and nothing happens.
  • Restarted the Spark multiple times
  • Performed a full reset (12 seconds on RST button)
  • Re-added the device in the app
  • Tried to trigger irrigation manually from both the app and the controller
  • Confirmed that the system works when I open the valves manually from the controller
  • Tried different power supplies
  • Connected to a mobile hotspot instead of my home Wi-Fi (same result)
  • Updated the firmware to the latest version (v3.3.0)
  • Purchased a brand new Spark controller and tested it — same exact issue
At this point, it looks like the issue is not hardware or network-related.
Could it be a firmware bug or a server-side problem?
Any help would be greatly appreciated!
Thanks in advance,
Stefano Mauri
浏览: 4679   回复: 3
Issue with Netro Spark
Fabrice GOUFFRAN
更新时间 2025-07-23 06:34:33 UTC
浏览: 4491   回复: 2
Andrew Woods
更新时间 2025-07-22 19:30:55 UTC
浏览: 4216   回复: 1
Stefano
更新时间 2025-07-21 21:17:23 UTC
Hi everyone,
I’ve already tried:
Thanks in advance!
– Stefano
浏览: 6786   回复: 1
Franck FONTANEL
更新时间 2025-07-18 19:49:49 UTC
I don’t know why ?
浏览: 6209   回复: 1
nsutherland
更新时间 2025-07-14 01:33:11 UTC
浏览: 4000   回复: 1
Veronica Slaughter
更新时间 2025-07-03 12:43:45 UTC
浏览: 6343   回复: 0
Valve not opening
更新时间 2025-07-01 05:11:54 UTC
I have a Netto controller 12
浏览: 6016   回复: 1
Font size/ dark mode
更新时间 2025-06-28 04:53:19 UTC
浏览: 6243   回复: 1
Jack De Donato
更新时间 2025-06-26 11:48:52 UTC
Question in subject title
浏览: 5735   回复: 0
Netro Sprite
Cassio
更新时间 2025-06-26 08:43:13 UTC
Thanks for your support!
浏览: 6292   回复: 2
Plant needs
Bob Benny
更新时间 2025-06-19 00:30:05 UTC
Thank you for your help.
浏览: 5504   回复: 1
更新时间 2025-06-18 03:59:06 UTC
浏览: 5822   回复: 1
Lorenzo Bigagli
更新时间 2025-06-14 12:02:48 UTC
Please
浏览: 5183   回复: 1
Alessandro Mason
更新时间 2025-06-09 22:08:10 UTC
浏览: 5381   回复: 1
Bart Abbott
更新时间 2025-06-07 12:43:42 UTC
浏览: 5445   回复: 1
Indicator led is burn out
yigal
更新时间 2025-06-07 12:18:46 UTC
浏览: 5404   回复: 1
Dropped wifi (2.4 Gz)
C Hill
更新时间 2025-06-06 02:10:45 UTC
浏览: 5538   回复: 1
