Best sync option?
jbart65
更新时间 2020-04-22 02:56:17 UTC
浏览: 6972   回复: 1
google home not connected
maxtrash
更新时间 2020-04-21 23:01:57 UTC
what could be going on?
浏览: 6715   回复: 2
Keep Connected option
jbart65
更新时间 2020-04-17 17:38:10 UTC
The particulars:
浏览: 6986   回复: 1
Which Alexa app?
jbart65
更新时间 2020-04-16 20:00:55 UTC
Jeffry
浏览: 7076   回复: 1
Netro app on google home
Danilo
更新时间 2020-04-11 10:07:58 UTC
Thanks for your support.
浏览: 6826   回复: 1
Settings
Massimo Povolo
更新时间 2020-04-07 06:31:48 UTC
浏览: 7782   回复: 5
Home Assistant integration
Casey S
更新时间 2020-04-05 19:46:53 UTC
浏览: 7550   回复: 2
duerson
更新时间 2020-03-27 20:59:20 UTC
浏览: 7154   回复: 1
Delivering term please
yodiego
更新时间 2020-03-14 18:08:21 UTC
浏览: 6605   回复: 1
alexa & pixie
stefano banfi gaslini
更新时间 2020-03-11 14:30:37 UTC
hi,
TNKS
best regards
stefano
浏览: 6943   回复: 1
更新时间 2020-02-28 07:49:20 UTC
浏览: 11213   评论: 3
Changing ownership of home
Dario Sindicich
更新时间 2020-02-14 01:48:40 UTC
浏览: 8485   回复: 2
Robert Bayes
更新时间 2020-02-07 03:39:19 UTC
浏览: 6493   回复: 1
Introducing the Referral Program
更新时间 2019-12-10 03:02:22 UTC
To the Netro community:
We are pleased to launch the Netro Referral Program. You can earn reward points when your friends become Netro customers!
1.Invite your friends to join Netro using your unique link
2.Your friends get a discount or reward points
Your friends enjoy 10% off their first orders or $10 credits toward their first subscriptions.
3.Get your reward points and repeat to earn more
You will earn reward points* equivalent in value to the discounts or credits given to your friends.
*Reward points: for every US dollar your friends spend on their first orders you will earn 10 points ($0.1). You will earn 1000 points ($10) for every friend who chooses to subscribe. There are 3 ways to redeem the reward points:
1. Use the reward points to purchase Netro products at netrohome.com (100 points = 1 US dollar)
2. Use the reward points to pay for your subscription fee at netrohome.com (100 points = 1 US dollar)
3. Withdraw the reward points to your PayPal account (200 points = 1 US dollar)
Your reward points will never expire.
You can check more info about Netro's Referral Program here https://netrohome.com/shop/refer
浏览: 8460   回复: 2
Raining but still watering
Liaqat Khan
更新时间 2019-12-08 00:23:51 UTC
浏览: 6797   回复: 1
Manuel Roca
更新时间 2019-11-22 17:20:29 UTC
This is an easy question
浏览: 7455   回复: 2
Daylight savings
Craig Neidle
更新时间 2019-11-13 18:34:27 UTC
Haow can i change this?
浏览: 7561   回复: 1
What about blowout?
Burghardi
更新时间 2019-10-18 02:06:15 UTC
Why doesn’t this one?
浏览: 7409   回复: 2
sqwu
更新时间 2019-09-30 13:51:09 UTC
浏览: 7586   回复: 1
hanz.blatt@gmail.com
更新时间 2019-09-29 13:59:02 UTC
浏览: 13341   回复: 2
