Offline since a couple of days
Daniel Torres
Actualizado 2022-05-15 10:01:39 UTC
Since a couple of days my Netro is offline. I have connected to my Netro to add the wifi password again and rebooted the router 3 times but still offline.
Ver: 3667   Respuesta: 1
Sprinklers only turn for a few second
Gabriele Wiel
Actualizado 2022-05-15 11:11:42 UTC
good morning
just installed his transformer burned out I had an electrician install a new transformer, now it works but the sprinklers only turn on for a few seconds, what can it be
This is a photo new transformer
Ver: 4128   Respuesta: 2
Weather .
Gianluca De Virgilio
Actualizado 2022-05-15 17:39:09 UTC
Good afternoon. The Weather forecast avvailable are absolutelly not real. What can I do?
Could you help me to con figure weather underground?
Ver: 3752   Respuesta: 2
Fabrice GOUFFRAN
Actualizado 2022-05-16 18:02:23 UTC
Good morning, Italy is my home, I recently started to use Netro replacing an old watering device I have used for several years, so far happy with my choice. I have one whisperer sensor device and I need 2 more but they are sold out on your online website, Amazon italy is also sold out with no forecast on new availability, where can I buy ?. Thank you.
Ver: 4196   Respuesta: 2
Restrictions do not include minute limits
Cheryl Michael
Actualizado 2022-05-17 03:03:27 UTC
I cannot find a way to reduce the minutes each station is watered. All stations on Eco boost. And some water almost an hour total (in 3 sessions) on allowed watering days. Our local So Cal restrictions are 10 minutes per station! How do I restrict  this?
Ver: 3456   Respuesta: 1
Bruno
Actualizado 2022-05-17 19:49:58 UTC
Ver: 3792   Respuesta: 1
Home Tab
bdcfam
Actualizado 2022-05-18 04:36:33 UTC
Ver: 3687   Respuesta: 1
Text in gray
Ignacio Sánchez
Actualizado 2022-05-18 11:26:32 UTC
Ver: 3480   Respuesta: 1
Pixie automatic water
Shirley Johnson
Actualizado 2022-05-18 18:20:36 UTC
My pixie won’t find my Wi-Fi. I’ve rebooted my router but didn’t help.
Ver: 4075   Respuesta: 1
Emilio
Actualizado 2022-05-20 17:05:31 UTC
Buenas tardes,
Pronóstico o expectativas.
Ver: 3449   Respuesta: 1
aspidiscelis
Actualizado 2022-05-20 19:16:08 UTC
Ver: 5047   Respuesta: 2
Smart Zone Scheduling Problem
Jon Storch
Actualizado 2022-05-20 22:11:43 UTC
Hello.  After turning on my sprinkler system back on for the summer this year the Netro has not worked correctly when in Smart Zone mode.
The scheduler will add a dozen of "mini" watering tasks where the next tasks starts immediately after the current one ends. (See picture)
I have tried resetting the system.  I currently need to have the Netro system disabled and run manual tasks to water my lawn.  What can I do to have my zones in Smart Zone mode and not have this problem?
Ver: 4125   Respuesta: 1
John Rowe
Actualizado 2022-05-21 00:45:45 UTC
Ver: 4871   Respuesta: 4
Battery in Pixie Reads 282%
David Halpern
Actualizado 2022-05-21 13:50:23 UTC
Ver: 4138   Respuesta: 2
Actualizado 2022-05-21 17:31:03 UTC
Ver: 4086   Respuesta: 1
malfunction
Ramón Sellés
Actualizado 2022-05-22 10:28:57 UTC
volume_up
content_copy
share
Ver: 3700   Respuesta: 1
MQTT port is blocked
Jose Juan Dios
Actualizado 2022-05-22 11:51:44 UTC
Can you help me please?
Thankyou
Ver: 3865   Respuesta: 1
Actualizado 2022-05-23 14:33:07 UTC
Ver: 4892   Respuesta: 1
Meteo app
Enrico Marion
Actualizado 2022-05-23 17:03:37 UTC
Ver: 3677   Respuesta: 1
Night watering
John Kot
Actualizado 2022-05-23 21:15:34 UTC
Ver: 3943   Respuesta: 1
