Davide M.
Actualizado 2022-04-20 09:23:18 UTC
Good day all,
Thanks for help.
Davide
Ver: 3815   Respuesta: 1
ITA Translation
Davide M.
Actualizado 2022-04-20 07:21:19 UTC
Hi all,
Best Regards,
Davide
Ver: 3708   Respuesta: 1
Blinking light on my Netro
RMeador
Actualizado 2022-04-21 01:20:07 UTC
Ver: 3303   Respuesta: 1
doppia irrigazione
mauro croce
Actualizado 2022-04-22 10:52:27 UTC
Ver: 3862   Respuesta: 1
Whisper Sensor
Ian Moore
Actualizado 2022-04-26 02:55:10 UTC
Ver: 3860   Respuesta: 1
Brian Brun
Actualizado 2022-04-26 04:23:12 UTC
Ver: 3793   Respuesta: 1
Calendar won’t update
Yuanchao X
Actualizado 2022-04-26 19:44:49 UTC
Ver: 3472   Respuesta: 2
J H
Actualizado 2022-04-26 20:17:38 UTC
Ver: 3638   Respuesta: 1
Activity not showing on ap
Mark Killeen
Actualizado 2022-04-27 15:21:38 UTC
Ver: 3764   Respuesta: 1
Netro Whisperer
Fabrice GOUFFRAN
Actualizado 2022-04-28 12:29:53 UTC
I am unable to have my new whisperer working. It doesn’t light on even after half a day under the sun.
Ver: 4375   Respuesta: 1
Incorrect rainfall accumulation
rwflower
Actualizado 2022-04-29 16:35:33 UTC
I live in Katy Texas and have been using the Netro water controller in smart mode for over 2 years with no problems.  We received at least 1.5in of rain on the April 25, so I was dismayed to find my sprinkler system watering my yard on the morning of the 26th.  The rain graph in the app is showing 0.03in for the 25th and is clearly wrong.  I have tried changing to all the different weather providers, but the total rain accumulation doesn't change.  The frontal system that caused the rain passed over the entire area, so this is not a situation of local shower only affecting a localized area.
Ver: 4047   Respuesta: 2
Location outside USA
Eduardo Prieto
Actualizado 2022-04-30 09:45:16 UTC
I live in Spain and ubication selector do not let me specify my correcto location. I assume It is requieres to provide the Meteorological service the place where to predict weather, so if location is incorrect, the weather too and the watering planning is not optimized properly.
Please work It out un Next app releases.
Ver: 3656   Respuesta: 1
Dhar Sawh
Actualizado 2022-05-01 13:26:09 UTC
Dhar
Ver: 3796   Respuesta: 2
Pixie shows "communicating" and timer counting down but valve not open?
Douglas Ely
Actualizado 2022-05-01 15:54:22 UTC
When trying to use the Pixie to manually water the garden, I go to the Netro app and select the pixie. It shows "sleeping", 99%charged. I then select "manual run" and set a time. The app then grays out and says "communicating" as the timer begins counting down my preset manual time but the valve stays closed. Why? When does it open?
Ver: 4475   Respuesta: 3
Wifi reconnect issue
Giacomo
Actualizado 2022-05-03 21:04:03 UTC
Hi All,
I'm a satisfied Italian customer of Netro Sprite 12 zones since 2019!
Recently I set my router to shutdown the wifi during the night, the Netro sprite it's the only one device that don't automatically reconnect when wifi come up in the morning, the white LED still blinking. To reconnect at the network, I need to phisically shutdown and power on the Sprite.
Is there a "trick" or an update to cover this issue? HW Version: 1.2 , Firmware Version 1.1.3
Thanks in advance.
Giacomo
Ver: 5125   Respuesta: 5
Rain stop
Javier Baruque
Actualizado 2022-05-03 14:52:20 UTC
Ver: 3532   Respuesta: 1
water valve does not work
Paolo Raviolo
Actualizado 2022-05-03 15:55:47 UTC
I set up the pixie timer, everithing seems ok but the valve does not opens, nor with program nor in manual mode, no water at all.
can you help me?
Ver: 3723   Respuesta: 1
No moisture reading
dsingelyn
Actualizado 2022-05-04 17:59:14 UTC
Suggestions?
Ver: 4000   Respuesta: 3
Smart watering -how do I know
John Kot
Actualizado 2022-05-05 21:44:57 UTC
If I have smart watering enabled does it activate sprinklers when it (sprite) determines a need?  If so how do I prevent that when I happen to be mowing the lawn?
Ver: 3953   Respuesta: 1
mspenner3
Actualizado 2022-05-06 00:09:34 UTC
Ver: 3515   Respuesta: 1
