Unable to save programs
Arnaud
Actualizado 2022-05-08 13:27:21 UTC
Hello, when I program the repeated watering schedules, it does not appear in the calendar and nothing happens.
Ver: 3324   Respuesta: 1
How do I test the sprinkler system
themaguires4727
Actualizado 2022-05-08 22:44:59 UTC
The instructions on page 12 of the Netro sprite quick start guide says I can use the ‘remote control’ feature to on the Netro app to turn on and off the sprinklers. I can’t find a ‘remote control’ setting on this app.
This entire system is making me feel like an idiot. Please help.
Ver: 3337   Respuesta: 1
Jonas Lindholm
Actualizado 2022-05-09 02:22:56 UTC
Ver: 3423   Respuesta: 1
Watering out of schedule time
Luca Cerini
Actualizado 2022-05-09 09:14:09 UTC
Luca
Ver: 3496   Respuesta: 1
Rain Strategy
Luca Cerini
Actualizado 2022-05-09 09:24:20 UTC
Luca
Ver: 3520   Respuesta: 1
SoCal Mandatory "Once a Week" Watering
Jonathan B.
Actualizado 2022-05-09 16:14:12 UTC
I've been given a notice that my county will require "Once weekly" watering beginning in June 2022. Will my Netro Sprite automatically adhere to this schedule or do I have to set it up myself?
Ver: 4227   Respuesta: 3
Broken part
Jeremie Coderre
Actualizado 2022-05-10 02:52:42 UTC
Hi there!
Thanks in advance!
Ver: 3627   Respuesta: 1
Rain Delay Setting
Nicholas Lydakis
Actualizado 2022-05-10 17:37:16 UTC
Ver: 3999   Respuesta: 1
pollomito
Actualizado 2022-05-10 19:31:57 UTC
Netro spark can be configured and used as timer if no wifi access point are available?
It is possible to use it by connecting directly mobile phone with spark without additional devices?
Thx
Ver: 4292   Respuesta: 2
instruction manual of the Netro Sprinkler
Rolando Silvano
Actualizado 2022-05-11 18:59:03 UTC
Where can I find the instruction manual of the Netro Sprinkler Smart Controller?
thank you
Silvano
Ver: 3806   Respuesta: 1
Interface language
Bayoule Bayoule
Actualizado 2022-05-11 19:31:03 UTC
Bayoule
Ver: 3495   Respuesta: 1
Actualizado 2022-05-11 19:37:04 UTC
Ver: 3715   Respuesta: 1
Netro not connecting
hawkshah
Actualizado 2022-05-12 02:02:39 UTC
I have switched internet providers and now Netro won’t connect to att modem.  I have run through setup many times
Ver: 3358   Respuesta: 1
stelio
Actualizado 2022-05-13 00:33:14 UTC
Netro working fine last summer , I can seem
To get it to stay online . I reset the Netro and it work fine for the first 10 min … then it logs off and leave on zone open . I don’t know what to do ,To keep it online ?
Ver: 3665   Respuesta: 1
Invalid station id WU
Richard B
Actualizado 2022-05-13 00:47:24 UTC
Ver: 3464   Respuesta: 1
Invalid station WU
Bayoule Bayoule
Actualizado 2022-05-13 03:51:52 UTC
JM
Ver: 3538   Respuesta: 1
How do I set on/off times?
Rikki Swin
Actualizado 2022-05-13 17:37:43 UTC
How do I program the on/off time on the new software? I need to have gaps between zones for pressure to rebuild. The new software is not intuitive!!!
Ver: 3338   Respuesta: 1
Manual Run
Dick Goddard
Actualizado 2022-05-13 20:53:29 UTC
Please help
Ver: 3837   Respuesta: 2
Good evening It but impossible to connect me netro tells me to make sure that the correct WIFI password is entered ... I have been trying to appear for 4 hours
GERMONT Alain
Actualizado 2022-05-13 23:02:49 UTC
Good evening
Ver: 3828   Respuesta: 3
Programación
jmgrau
Actualizado 2022-05-15 05:30:10 UTC
Buenos dias, como tengo que programar para que la schedule no actúe solamente funcionen los programas que yo programe.
Si programo algún programa, ahora me sale la schedule también.
Ver: 3853   Respuesta: 1
