Matt Ward
Lives in: Granbury, TX, US
Using: SPARK-16
Growing: Mexican Fan Palm, Bermuda
Questions
Change zone order
39
Matt Ward
Updated at 2025-07-22 00:43:18 UTC
Topic: Netro App
Open Circuit Master Valve
39
Matt Ward
Updated at 2024-04-08 23:44:05 UTC
Topic: Troubleshooting
My system is not working. When I run a valve test, it shows all valves are normal but the master valve has an open circuit error. I have checked all the wires and there is not voltage at the wires at the valve itself. I used a volt meter at the Netro controller and there is no voltage coming out of the controller for the master valve. Any suggestions?
Matt
Smart mode initial watering
39
Matt Ward
Updated at 2023-06-02 01:19:52 UTC
Topic: Connected Home
39
Matt Ward
Updated at 2023-04-14 13:57:11 UTC
Topic: Smart Watering
Matt
