Lives in: Sudbury, MA, US
Using: PIXIE-1 , WHISPERER-1
Growing: Coleus, Pompon Dahlia
Questions
27
Updated at 2022-09-07 21:08:59
Topic: Netro App
Can Pixie measure water flow?
27
Updated at 2022-08-23 14:09:01
Topic: Smart Watering
27
Updated at 2022-08-21 09:13:22
Topic: Netro App
Why gap in smart schedule?
27
Updated at 2022-08-19 00:35:41
Topic: Netro App
27
Updated at 2022-08-19 00:34:04
Topic: Netro App
I set the smart schedule to go on at 50%. The app says if it goes below low, it will water till it gets to high It’s set to a low of 50 and you can clearly see it let i…
Sync warning even when online
27
Updated at 2022-08-16 19:08:38
Topic: Netro App
I get this warning when I try to add a manual run to the schedule, even when I just woke up the timer outside and even the app home page says it’s online  there is no way around…
27
Updated at 2022-08-11 20:18:04
Topic: Netro App
I use the facet tuner for drip irrigation to my dahlias. I want the custom setting to have it run at 40% until it gets to 90% There is a flow rate with a default option. Is th…
Day view
27
Updated at 2022-07-12 04:10:37
Topic: Netro App
Hi Unless I’m missing how to change it, I think today view can only be set to the current day Here it just passed midnight and I want to see yesterday. Would be …
27
Updated at 2022-07-10 11:25:02
Topic: Netro App
27
Updated at 2022-07-02 17:31:23
Topic: Netro App
27
Updated at 2022-06-19 18:52:23
Topic: Netro App
For my whisper, what is k lic sunlight?  I googled it and it’s intensity. Like direct sun has higher lux  than overcast I can’t tell from the app how much hours of good…
