Consistently underwatering
Douglas Ely
Updated at 2022-08-02 10:14:34 UTC
View: 6335   Answer: 1
Severe water restrictions
Michael Wheatley
Updated at 2022-07-31 02:18:20 UTC
View: 4526   Answer: 1
Offline
Francesco V
Updated at 2022-07-30 22:01:37 UTC
View: 4377   Answer: 1
Wrong scheduling?
Carlos Jimeno
Updated at 2022-07-30 07:49:09 UTC
Any ideas to solve it?.
Thank you very much.
View: 5713   Answer: 1
Whispered wrong temperature range?
Updated at 2022-07-29 17:51:27 UTC
I had just installed 3 whisper and two of them are showing temperature o 3xxx °C, while the third one is correct.
Is this normal? Or will be auto updated?
View: 6408   Answer: 2
Alex Heath
Updated at 2022-07-28 17:46:04 UTC
View: 5351   Answer: 1
Old v new
Updated at 2022-07-28 17:19:05 UTC
Andy
View: 4762   Answer: 1
manual runs not working
john streit
Updated at 2022-07-28 13:23:25 UTC
View: 4033   Answer: 1
Change the location
JAVIER FRESNO
Updated at 2022-07-27 16:50:51 UTC
Juan Brea
Updated at 2022-07-26 18:08:13 UTC
View: 5788   Answer: 1
Updated at 2022-07-26 05:14:15 UTC
View: 6376   Answer: 2
Shane Lopez
Updated at 2022-07-25 20:14:33 UTC
View: 5971   Answer: 1
Whisperer and Rachio
Billy Clark
Updated at 2022-07-25 19:19:29 UTC
View: 5451   Answer: 0
Erroneous "smart" scheduling
Updated at 2022-07-25 18:57:45 UTC
View: 6080   Answer: 1
The app has a bug
Updated at 2022-07-25 16:56:01 UTC
View: 5994   Answer: 2
Mario Brusasco
Updated at 2022-07-25 13:56:44 UTC
View: 4140   Answer: 1
Wishper sensor
Updated at 2022-07-24 13:18:57 UTC
Hi all.
Best regards,
View: 4392   Answer: 1
sumopromos
Updated at 2022-07-23 12:38:33 UTC
Hey All!
View: 5464   Answer: 1
Repuesto
Juan Pascual
Updated at 2022-07-23 08:12:17 UTC
Buenos días desde España
Mil gracias
View: 6327   Answer: 2
maximelabelle@hotmail.com
Updated at 2022-07-20 22:56:46 UTC
View: 5541   Answer: 2
