Pedro Abad
更新時間 2021-05-30 08:33:28 UTC
Thank you all!
瀏覽: 4151   回覆: 2
Douglas Peale
更新時間 2021-05-27 22:32:59 UTC
瀏覽: 4004   回覆: 1
banaszar
更新時間 2021-05-25 17:23:58 UTC
瀏覽: 3820   回覆: 2
Brad Grizzly
更新時間 2021-05-23 03:42:20 UTC
瀏覽: 3805   回覆: 1
bad wireless?
amagalla
更新時間 2021-05-19 16:50:44 UTC
Tony
瀏覽: 4055   回覆: 1
amagalla
更新時間 2021-05-19 16:45:52 UTC
Edit:
The app on my tablet shows:
Server Status:    OK
Response time:  0.3 s
瀏覽: 4789   回覆: 2
Whisperer connexion
更新時間 2021-05-19 14:52:55 UTC
瀏覽: 4597   回覆: 2
Turning off wayer
更新時間 2021-05-16 21:29:12 UTC
瀏覽: 4270   回覆: 2
Seed watering
Adrian Azzopardi
更新時間 2021-05-16 10:18:05 UTC
瀏覽: 3914   回覆: 1
Update Firmware
Tognaz
更新時間 2021-05-10 12:35:23 UTC
Hello everyone,
Checking with the Netro app, I see that my Sprite has firmware version 2.2.0, while I think I read in the forum that there is version 2.5.3.
How can I force the update?
瀏覽: 4035   回覆: 1
Latest software update
Sheryl New
更新時間 2021-05-02 21:59:11 UTC
Is 2.5.3 the latest Netro Sprite software version?
瀏覽: 5420   回覆: 3
Internet connection
Sheryl New
更新時間 2021-05-02 21:57:36 UTC
My Netro Sprite constantly drops offline. Help, please.
瀏覽: 3994   回覆: 2
soil fertility
更新時間 2021-05-02 15:17:33 UTC
Why the Whisperer doesn’t measure the soil fertility?
瀏覽: 4107   回覆: 1
I live in the US but want my temperature in celsius
smartplastic
更新時間 2021-04-27 00:19:53 UTC
Hi I’m and Aussie living in the US and although I am happy to use pounds and feet etc Fahrenheit is just a ridiculous pile of crap that is used nowhere else in the world.
How can I get the temperature display in my Netro app to show in Celsius?
瀏覽: 3825   回覆: 1
Netro app discover tab
Zee D
更新時間 2021-04-25 20:52:09 UTC
瀏覽: 3825   回覆: 1
LAWN
更新時間 2021-04-23 23:08:09 UTC
Set up wifi
Neti URC - 87B (ok saved)
home netwok connected.
瀏覽: 3977   回覆: 1
Email address
Troy pascoe st
更新時間 2021-04-19 11:01:30 UTC
瀏覽: 3900   回覆: 1
dougbrandes
更新時間 2021-04-19 10:06:30 UTC
瀏覽: 3897   回覆: 1
Multiple Pixies?
J Forrest
更新時間 2021-04-17 03:33:18 UTC
瀏覽: 3919   回覆: 1
How to delete a device
Carles
更新時間 2021-04-16 12:33:31 UTC
瀏覽: 4159   回覆: 1
