Pause a location\device
Jon Storch
更新時間 2021-06-06 23:08:20 UTC
-Jon Storch
瀏覽: 2967   回覆: 1
Manual Watering
Kevin Westling
更新時間 2021-06-04 00:42:16 UTC
瀏覽: 2918   回覆: 1
sal.jamil@me.com
更新時間 2021-06-02 12:11:24 UTC
瀏覽: 2854   回覆: 1
60 minute limit
C S
更新時間 2021-06-01 21:33:39 UTC
瀏覽: 2734   回覆: 1
Yuriy Andamasov
更新時間 2021-05-31 19:44:41 UTC
Thanks in advance.
瀏覽: 2806   回覆: 1
Pedro Abad
更新時間 2021-05-30 08:33:28 UTC
Thank you all!
瀏覽: 3028   回覆: 2
Douglas Peale
更新時間 2021-05-27 22:32:59 UTC
瀏覽: 2901   回覆: 1
banaszar
更新時間 2021-05-25 17:23:58 UTC
瀏覽: 2733   回覆: 2
Brad Grizzly
更新時間 2021-05-23 03:42:20 UTC
瀏覽: 2710   回覆: 1
bad wireless?
amagalla
更新時間 2021-05-19 16:50:44 UTC
Tony
瀏覽: 2916   回覆: 1
amagalla
更新時間 2021-05-19 16:45:52 UTC
Edit:
The app on my tablet shows:
Server Status:    OK
Response time:  0.3 s
瀏覽: 3635   回覆: 2
Whisperer connexion
更新時間 2021-05-19 14:52:55 UTC
瀏覽: 3403   回覆: 2
Turning off wayer
更新時間 2021-05-16 21:29:12 UTC
瀏覽: 3114   回覆: 2
Seed watering
Adrian Azzopardi
更新時間 2021-05-16 10:18:05 UTC
瀏覽: 2826   回覆: 1
Update Firmware
Tognaz
更新時間 2021-05-10 12:35:23 UTC
Hello everyone,
Checking with the Netro app, I see that my Sprite has firmware version 2.2.0, while I think I read in the forum that there is version 2.5.3.
How can I force the update?
瀏覽: 2961   回覆: 1
Latest software update
Sheryl New
更新時間 2021-05-02 21:59:11 UTC
Is 2.5.3 the latest Netro Sprite software version?
瀏覽: 4152   回覆: 3
Internet connection
Sheryl New
更新時間 2021-05-02 21:57:36 UTC
My Netro Sprite constantly drops offline. Help, please.
瀏覽: 2897   回覆: 2
soil fertility
更新時間 2021-05-02 15:17:33 UTC
Why the Whisperer doesn’t measure the soil fertility?
瀏覽: 2988   回覆: 1
I live in the US but want my temperature in celsius
smartplastic
更新時間 2021-04-27 00:19:53 UTC
Hi I’m and Aussie living in the US and although I am happy to use pounds and feet etc Fahrenheit is just a ridiculous pile of crap that is used nowhere else in the world.
How can I get the temperature display in my Netro app to show in Celsius?
瀏覽: 2745   回覆: 1
Netro app discover tab
Zee D
更新時間 2021-04-25 20:52:09 UTC
瀏覽: 2749   回覆: 1
