Adjusting for tree cover
Steve M
更新時間 2024-06-30 23:47:30 UTC
瀏覽: 2071   回覆: 1
app crashing
Christoforos
更新時間 2024-06-28 14:13:56 UTC
Can you please help.
Christoforos
瀏覽: 2113   回覆: 1
Where is the documentation on how to use the app?
Lance Blaise
更新時間 2024-06-20 03:41:17 UTC
Where is the documentation on how to use the app? I have no clue how to set my own schedule or how to use the smart scheduling... I can't find anything on how to use this app at all and it's pretty confusing. I am looking at the app and it seems to have smart watering enabled, but there are times where it's skipping 3 days randomly and there is no rain that is supposed to take place on those days, so no clue why it's skipping those days. Can someone direct me to where the documentation is for using the app?  Thank you.
瀏覽: 2109   回覆: 1
network error
更新時間 2024-06-18 10:24:07 UTC
i have a Netro app
on ios with a 12 station
Starting this morning i receive a
Network error message
i restarted/ re connect
same message
May i need a new firmware ?
瀏覽: 2376   回覆: 3
Change whisperer mode
Jure
更新時間 2024-06-15 11:33:22 UTC
What is the proper way for changing Whisperer from standalone mode to adding it to my Netro Pixie or Sprite?
瀏覽: 2175   回覆: 1
Where to see Whisperer data collected in the Netro App ?
JDo REY
更新時間 2024-06-07 09:01:29 UTC
Where to see Whisperer data collected in the Netro ?
瀏覽: 2170   回覆: 2
Rainbird R Van rotator
更新時間 2024-06-04 19:09:06 UTC
Hi there
瀏覽: 2222   回覆: 3
Shut off one zone
Wil
更新時間 2024-05-31 04:05:40 UTC
瀏覽: 2209   回覆: 2
Javier NM
更新時間 2024-05-26 06:32:56 UTC
瀏覽: 2231   回覆: 1
PREFERRED ARTICLES
Javier NM
更新時間 2024-05-12 06:36:42 UTC
瀏覽: 2366   回覆: 1
Help!
John Zuzula
更新時間 2024-05-02 14:46:09 UTC
瀏覽: 2289   回覆: 1
Manual operation doesn’t stop
Ciro Bracciante
更新時間 2024-04-29 11:31:14 UTC
瀏覽: 2180   回覆: 1
App Netro
Antonio Cordon Rodriguez
更新時間 2024-04-28 09:28:48 UTC
瀏覽: 2169   回覆: 0
Fabio F
更新時間 2024-04-20 14:28:45 UTC
 How do I solve this problem?
瀏覽: 2554   回覆: 4
Bob Cohen
更新時間 2024-04-15 23:49:36 UTC
瀏覽: 2487   回覆: 2
Exclamation on Schedule
Oilol
更新時間 2024-04-10 12:56:31 UTC
Thanks in Advance!
Tim
瀏覽: 2427   回覆: 1
2 whisperer to 1 pixie
Paolo S
更新時間 2024-04-02 20:28:39 UTC
瀏覽: 2411   回覆: 1
Forecast doesn't show
Edan Manos
更新時間 2024-03-31 05:34:57 UTC
瀏覽: 2363   回覆: 1
Manual Operation
Mario Hardy
更新時間 2024-03-21 12:47:06 UTC
瀏覽: 2463   回覆: 1
Multiple watering a day
Phil Rubin
更新時間 2024-02-17 04:33:52 UTC
I need to run watering programs 2-3 times in a day, every day. I have "two fra m es" checked but it only will do one.  What do I  need to do?
瀏覽: 2641   回覆: 2
