Where to see Whisperer data collected in the Netro App ?
JDo REY
更新時間 2024-06-07 09:01:29 UTC
Where to see Whisperer data collected in the Netro ?
瀏覽: 3350   回覆: 2
Rainbird R Van rotator
更新時間 2024-06-04 19:09:06 UTC
Hi there
瀏覽: 3584   回覆: 3
Shut off one zone
Wil
更新時間 2024-05-31 04:05:40 UTC
瀏覽: 3405   回覆: 2
Javier NM
更新時間 2024-05-26 06:32:56 UTC
瀏覽: 3431   回覆: 1
PREFERRED ARTICLES
Javier NM
更新時間 2024-05-12 06:36:42 UTC
瀏覽: 3569   回覆: 1
Help!
John Zuzula
更新時間 2024-05-02 14:46:09 UTC
瀏覽: 3504   回覆: 1
Manual operation doesn’t stop
Ciro Bracciante
更新時間 2024-04-29 11:31:14 UTC
瀏覽: 3352   回覆: 1
App Netro
Antonio Cordon Rodriguez
更新時間 2024-04-28 09:28:48 UTC
瀏覽: 3343   回覆: 0
Fabio F
更新時間 2024-04-20 14:28:45 UTC
 How do I solve this problem?
瀏覽: 3785   回覆: 4
Bob Cohen
更新時間 2024-04-15 23:49:36 UTC
瀏覽: 3628   回覆: 2
Exclamation on Schedule
Oilol
更新時間 2024-04-10 12:56:31 UTC
Thanks in Advance!
Tim
瀏覽: 3558   回覆: 1
2 whisperer to 1 pixie
Paolo S
更新時間 2024-04-02 20:28:39 UTC
瀏覽: 3630   回覆: 1
Forecast doesn't show
Edan Manos
更新時間 2024-03-31 05:34:57 UTC
瀏覽: 3505   回覆: 1
Manual Operation
Mario Hardy
更新時間 2024-03-21 12:47:06 UTC
瀏覽: 3632   回覆: 1
Multiple watering a day
Phil Rubin
更新時間 2024-02-17 04:33:52 UTC
I need to run watering programs 2-3 times in a day, every day. I have "two fra m es" checked but it only will do one.  What do I  need to do?
瀏覽: 3793   回覆: 2
Pump
Carmelo Anaya
更新時間 2024-02-12 20:44:48 UTC
I have 6 zones but only 4 require to switch on the pump. How can I switch the pump individually on each zone?
瀏覽: 3533   回覆: 1
Port 1883 is blocked by the touter
Gary Harpley
更新時間 2024-02-10 05:49:13 UTC
Hi. Im a new user and everytning seems to be working ss it should but i get the following message when i check the server status
瀏覽: 3535   回覆: 1
Weather Underground
Gary Harpley
更新時間 2024-02-06 06:06:14 UTC
Hi. The app wont let me add my wundergound id number (IWAGGA24). Can you please help
瀏覽: 3496   回覆: 1
Data records
David Lrx
更新時間 2024-02-03 12:14:57 UTC
Is it possible to upload data from the app so I can keep record on an externat file for more than a month ?
I would like to keep record for a year long.
David.
瀏覽: 3501   回覆: 1
Manual run times need to be longer and editable while running
Richard
更新時間 2024-01-19 21:27:13 UTC
Hi Netro,
One frustration I have is that manual run times are important to me but cannot be longer than 1 hour (or programs) and cannot be adjusted while running.
I have Netro connected to a solenoid that controls watering of our small vineyard.
I rarely water in any way other than manual, because I need to control the amount of watering and also use fertigation to feed the vines.
Due to the amount of water required, I need between two to three hours of watering. I also like to adjust as I go, depending on how long the fertigation takes, so the ability to increase time without stopping the watering is also important.
My other solution is to disconnect the wire from Netro and use a Shelly 1 instead, whereby I can turn the watering on and off as I desire.
I would rather just use the Netro app, given that everything is already connected.
It is quite limiting to not allow hours as well as minutes (or to allow more than 60 minutes). amd not to be able to increase (or decrease) the time while the manual run is going.
瀏覽: 4071   回覆: 2
