Multiple sprinklers in one zone - and is there a Test System ?
Cormac Champion
更新時間 2020-09-19 13:48:55
Can zones be setup with several sprinklers in the one zone ?  From what I can see from another question, is it correct that you setup the aproximate size of each zone ?  I have several zones with maybe 10 sprinklers in each zone, with sprinklers about 3m apart.
Also, is there any access to a test / simulation system that I can setup my location and see how well it would adapt to weather.  I am planning the installation for southern Spain
Thanks in advance
瀏覽: 4092   回覆: 1
HomeOwner
Isaac Fishman
更新時間 2020-09-21 01:14:55
瀏覽: 3855   回覆: 1
Controller LED Light
Texas AF
更新時間 2020-09-22 14:01:57
瀏覽: 3836   回覆: 1
Second house
HaccasDave
更新時間 2020-09-29 18:20:51
I'm in the very fortunate position of having 2 homes - one in the UK and one in Spain. We've just had the garden reworked in the UK and I've been able to install an irrigation system controlled by a single Sprite controller.
I'm very pleased with how this is working - and now want to upgrade the manual irrigation system we have in our Spanish house to a smart system. Can Netrohome / the (Android) app manage 2 different irrigation systems in 2 different locations (with 2 very different climates)?
Many thanks.
瀏覽: 4003   回覆: 1
Atif Khan
更新時間 2020-10-01 14:21:57
瀏覽: 3788   回覆: 1
OFFLINE
Javier López-Guerrero
更新時間 2020-10-03 08:20:26
Help!
Javier
瀏覽: 3799   回覆: 2
Switch Off automatically
Carlos Jimenez
更新時間 2020-10-09 20:18:31
I found two cases,
瀏覽: 3920   回覆: 1
Simone Nolletti
更新時間 2020-10-11 11:46:06
Buonasera,
瀏覽: 4238   回覆: 1
Questions about Netro app
Luis Aguilar
更新時間 2020-10-11 17:47:55
瀏覽: 3925   回覆: 1
How stop 1 day
Leonardo Antonucci
更新時間 2020-10-11 18:33:55
瀏覽: 3839   回覆: 1
"Next in" shows "--"
Luis Aguilar
更新時間 2020-10-14 18:45:01
瀏覽: 3856   回覆: 1
Netro unit
Bhumit Joshi
更新時間 2020-10-16 18:15:51
I just got my system winterized today. Netro box is still on. Do i just unplug it for the winter?
瀏覽: 3956   回覆: 1
Problem With application
Alex Guerrero
更新時間 2020-10-17 08:21:08
瀏覽: 3874   回覆: 1
Manually entering rainfall
Curt Lizzi
更新時間 2020-10-17 13:16:09
瀏覽: 4045   回覆: 1
David Farries
更新時間 2020-10-24 20:24:40
瀏覽: 4086   回覆: 1
Email address length
Alberto Castro Hinojosa
更新時間 2020-10-24 21:37:57
Could you review please?
瀏覽: 3967   回覆: 1
Stefan Pena
更新時間 2020-10-25 10:41:41
Hey guys!
瀏覽: 3810   回覆: 1
New user
Haris Eliades
更新時間 2020-10-28 20:35:38
Hello!
Zone 4, 2 minutes
Zone 5, 2 minutes
Zone 1, 4 minutes
Zone 2, 4 minutes
Zone 3, 4 minutes
Zone 4, 4 minutes
Zone 5, 2 minutes
瀏覽: 3846   回覆: 1
How do I turn off for Winter?
Paul A
更新時間 2020-10-30 20:59:47
瀏覽: 3786   回覆: 2
Add zones manually in queue
Haris Eliades
更新時間 2020-11-03 04:04:49
瀏覽: 4039   回覆: 1
