Run Netro in one zone now
Stan Bumgarner
Actualizado 2020-03-28 20:15:35 UTC
Stan
Ver: 3141   Respuesta: 1
2 or more zone at same time
Mirko Paganelli
Actualizado 2020-03-28 15:32:05 UTC
Ver: 3283   Respuesta: 1
J H
Actualizado 2020-03-24 21:16:47 UTC
Ver: 3135   Respuesta: 1
App Crashes on adding product
Tarudro
Actualizado 2020-02-24 20:24:10 UTC
I just received my Pixie and Whisperer and wanted to set them up using my iPhone.
Therefore I launch the app and go to "Add Product", select the Pixie and then I'm promted to enter my location and a name for the timer.
When I click on "next" the app crashes and returns to the home screen. 100% reproducible. I tried to enter different adress and name, but couldn't make it work. Crashes every time.
Reinstall also didn't solve the problem.
Netro App: 2.4.0
iPhone 11 Pro
iOS 13.3.1
German (also tried English)
Let me know, if you need anything else to reproduce/solve this issue or if there is something that I could do to prevent it.
So far, I couldn't find anything in the forum here.
BR Lukas
PS. I just tried also on my iPad Air 2 - same crash.
Ver: 7036   Respuesta: 4
Soil Types
Tim Foster
Actualizado 2019-12-14 13:28:44 UTC
The app asks me to define my soil type and gives me a small list to choose from. I'm no gardening expert by any means and so I'm not really sure I've got this right. I selected the most draining type based on nothing more that guesswork really. We're in Yucatán, México so the entire area is limestone rock, but this website (https://sites.google.com/site/soilsoftheyucatanpeninsula/soil-types) gives more detail about the soil types in Yucatán. All this has done though is confuse me more.
Is there any reliable way that I can determine my soil type in Netro? The website says it's likely to be one (or a combination) of Gleysols, Histosols, Vertisols, Solonchaks, Leptosols, and Cambisols
Ver: 3513   Respuesta: 1
Can't add new managers
Tim Foster
Actualizado 2019-12-03 20:00:25 UTC
Ver: 3470   Respuesta: 1
Smart zone enabled
Steve Kalani
Actualizado 2019-11-25 18:36:19 UTC
Ver: 3298   Respuesta: 1
Schedule setup
Rich Christenson
Actualizado 2019-09-21 14:51:31 UTC
Ver: 3472   Respuesta: 1
Unit measurements
Homestead One
Actualizado 2019-09-17 20:29:09 UTC
Ver: 3485   Respuesta: 1
Feature request
Tony D.
Actualizado 2019-09-12 20:32:30 UTC
Tony
Ver: 3687   Respuesta: 1
Manual run time screen
Rich Christenson
Actualizado 2019-09-06 10:25:49 UTC
Ver: 3903   Respuesta: 1
Weather Provider
Martin Müller-Zantop
Actualizado 2019-08-22 10:57:44 UTC
Can you please explain to me the big difference of the next watering days using different weather providers? As you can see in my print screens the data of temperature and humidity are nearly the same. With one provider next watering cycle will be in 2 days and with another in 11 days.
Thank you for your comments
Martin
Ver: 4153   Respuesta: 2
One day restriction
Lou Infeld
Actualizado 2019-08-12 21:49:14 UTC
Ver: 3487   Respuesta: 1
Update application
Anyhony Harwood
Actualizado 2019-08-11 11:58:55 UTC
Ver: 3284   Respuesta: 1
Spanish translation
Juan P
Actualizado 2019-08-10 21:48:16 UTC
Ver: 4108   Respuesta: 3
Zip code
Homestead One
Actualizado 2019-08-10 11:09:29 UTC
Ver: 3445   Respuesta: 0
Plant Sensors Monitoring Multiple Zones
Actualizado 2019-08-07 06:39:15 UTC
To the Netro community:
We recently have launched an update for the Netro app on App Store and Google Play. In the newest version of the app, we allow one sensor to monitor up to 3 zones but the user needs to make sure the zones have similar environmental conditions.
Please upgrade your app to the newest version and go to Settings->Sensors, select a sensor, go to Zones and select the zones you would like to monitor.
After saving the changes, you can go to the Home page and check the topsoil moisture level of your zones reported by sensor.
Please feel free to explore other new and exciting features that we just added :
1.Support Apple Watch
(only available for iOS )
2.Support Weather Underground PWS
3.Rainfall adjustment
Ver: 5127   Comentario: 3
changing watering zone times?
Actualizado 2019-08-06 01:53:14 UTC
Ver: 3549   Respuesta: 1
OnePlus Venom
Actualizado 2019-07-29 03:48:51 UTC
What does that mean???
Ver: 3579   Respuesta: 1
Actualizado 2019-07-29 03:11:08 UTC
Add or delete users
 Access rights of shared users
Manager’s access rights:
Player’s access rights:
Ver: 7605   Comentario: 4
