Adjusting for tree cover
Steve M
Actualizado 2024-06-30 23:47:30 UTC
Ver: 2069   Respuesta: 1
app crashing
Christoforos
Actualizado 2024-06-28 14:13:56 UTC
Can you please help.
Christoforos
Ver: 2113   Respuesta: 1
Where is the documentation on how to use the app?
Lance Blaise
Actualizado 2024-06-20 03:41:17 UTC
Where is the documentation on how to use the app? I have no clue how to set my own schedule or how to use the smart scheduling... I can't find anything on how to use this app at all and it's pretty confusing. I am looking at the app and it seems to have smart watering enabled, but there are times where it's skipping 3 days randomly and there is no rain that is supposed to take place on those days, so no clue why it's skipping those days. Can someone direct me to where the documentation is for using the app?  Thank you.
Ver: 2107   Respuesta: 1
network error
Actualizado 2024-06-18 10:24:07 UTC
i have a Netro app
on ios with a 12 station
Starting this morning i receive a
Network error message
i restarted/ re connect
same message
May i need a new firmware ?
Ver: 2373   Respuesta: 3
Change whisperer mode
Jure
Actualizado 2024-06-15 11:33:22 UTC
What is the proper way for changing Whisperer from standalone mode to adding it to my Netro Pixie or Sprite?
Ver: 2172   Respuesta: 1
Where to see Whisperer data collected in the Netro App ?
JDo REY
Actualizado 2024-06-07 09:01:29 UTC
Where to see Whisperer data collected in the Netro ?
Ver: 2169   Respuesta: 2
Rainbird R Van rotator
Actualizado 2024-06-04 19:09:06 UTC
Hi there
Ver: 2216   Respuesta: 3
Shut off one zone
Wil
Actualizado 2024-05-31 04:05:40 UTC
Ver: 2205   Respuesta: 2
Javier NM
Actualizado 2024-05-26 06:32:56 UTC
Ver: 2224   Respuesta: 1
PREFERRED ARTICLES
Javier NM
Actualizado 2024-05-12 06:36:42 UTC
Ver: 2360   Respuesta: 1
Help!
John Zuzula
Actualizado 2024-05-02 14:46:09 UTC
Ver: 2285   Respuesta: 1
Manual operation doesn’t stop
Ciro Bracciante
Actualizado 2024-04-29 11:31:14 UTC
Ver: 2174   Respuesta: 1
App Netro
Antonio Cordon Rodriguez
Actualizado 2024-04-28 09:28:48 UTC
Ver: 2165   Respuesta: 0
Fabio F
Actualizado 2024-04-20 14:28:45 UTC
 How do I solve this problem?
Ver: 2550   Respuesta: 4
Bob Cohen
Actualizado 2024-04-15 23:49:36 UTC
Ver: 2484   Respuesta: 2
Exclamation on Schedule
Oilol
Actualizado 2024-04-10 12:56:31 UTC
Thanks in Advance!
Tim
Ver: 2421   Respuesta: 1
2 whisperer to 1 pixie
Paolo S
Actualizado 2024-04-02 20:28:39 UTC
Ver: 2402   Respuesta: 1
Forecast doesn't show
Edan Manos
Actualizado 2024-03-31 05:34:57 UTC
Ver: 2361   Respuesta: 1
Manual Operation
Mario Hardy
Actualizado 2024-03-21 12:47:06 UTC
Ver: 2455   Respuesta: 1
Multiple watering a day
Phil Rubin
Actualizado 2024-02-17 04:33:52 UTC
I need to run watering programs 2-3 times in a day, every day. I have "two fra m es" checked but it only will do one.  What do I  need to do?
Ver: 2629   Respuesta: 2
