What does the app show for whisperer?
Growbro
Actualizado 2021-03-17 20:54:48 UTC
I am trying to figure out what the graph shows for the week. It seems like the app shows the average light for the day. Moisture present at midnight each day. And average temperature each day. Is this correct? Or is it maximum temperature for the day?
It would be nice if I could have the graph could show more than just one reading per day. It would also be nice if you could go back and see the more detailed chart for a full day after it has passed. As it is now I can only see the one data point for days that are past.
Finally for the individual days it is a bit annoying switching between am and pm. I wish there was just a graph for each day that looked like the graph for the week/month except that there was a data point for every hour. Definitely more annoying and less useful to have am and pm separate and not be able to see the changes like you can with the graph.
Ver: 3310   Respuesta: 1
Foreca as weather provider
Fran Roman
Actualizado 2021-03-09 21:21:35 UTC
Please add Foreca as weather provider! In Europe is much better than the available options on the app. Metro group is also a good option for your European customers like me.
Ver: 3245   Respuesta: 1
Zone says Loading
Gale
Actualizado 2021-02-24 14:03:11 UTC
After the numerous power outages in Dallas last week, my sprinklers attempted to run this morning.   At its scheduled time, the zone shows "loading" but - no water.   ???
Ver: 3110   Respuesta: 1
Smart Watering Algorithm
Actualizado 2021-02-09 13:52:56 UTC
Ver: 3777   Respuesta: 1
Date Format
Brian Keenan
Actualizado 2021-01-29 09:00:07 UTC
Ver: 3289   Respuesta: 1
Geron R
Actualizado 2021-01-19 23:06:52 UTC
Please advise
Ver: 3426   Respuesta: 1
Metro France cloud down?
Julian Hansen
Actualizado 2020-12-29 01:07:40 UTC
Ver: 3669   Respuesta: 1
Roman Stanek
Actualizado 2020-12-27 18:34:40 UTC
Ver: 3178   Respuesta: 1
App stuck on Idle
Pam Manwaring
Actualizado 2020-11-18 02:21:16 UTC
Ver: 3314   Respuesta: 1
Stan Balafas
Actualizado 2020-11-16 17:52:28 UTC
Thank ypu
Ver: 3434   Respuesta: 1
Add zones manually in queue
Haris Eliades
Actualizado 2020-11-03 04:04:49 UTC
Ver: 3603   Respuesta: 1
"Next in" shows "--"
Luis Aguilar
Actualizado 2020-10-14 18:45:01 UTC
Ver: 3427   Respuesta: 1
Questions about Netro app
Luis Aguilar
Actualizado 2020-10-11 17:47:55 UTC
Ver: 3483   Respuesta: 1
Simone Nolletti
Actualizado 2020-10-11 11:46:06 UTC
Buonasera,
Ver: 3812   Respuesta: 1
Switch Off automatically
Carlos Jimenez
Actualizado 2020-10-09 20:18:31 UTC
I found two cases,
Ver: 3481   Respuesta: 1
Atif Khan
Actualizado 2020-10-01 14:21:57 UTC
Ver: 3365   Respuesta: 1
Simple on/off
gmcg1984
Actualizado 2020-09-17 01:54:35 UTC
Ver: 3437   Respuesta: 1
Start time change
Franco Storato
Actualizado 2020-09-16 06:00:59 UTC
Thank you in advance,
Franco
Ver: 3293   Respuesta: 1
Email too long in android app
Christoforos
Actualizado 2020-09-02 09:49:14 UTC
Ver: 3570   Respuesta: 1
Add manager
Fabio Pellizzoni
Actualizado 2020-08-27 08:26:50 UTC
Ver: 3517   Respuesta: 1
