Smart watering
John Jessee
Actualizado 2019-07-03 22:25:57 UTC
Ver: 4639   Respuesta: 1
Saurik
Actualizado 2019-07-04 07:12:42 UTC
Ver: 4865   Respuesta: 1
Home Assistant
David
Actualizado 2019-07-06 09:33:48 UTC
Ver: 5040   Respuesta: 1
Reset Moisture Level
firewally
Actualizado 2019-07-06 14:06:03 UTC
Ver: 4977   Respuesta: 1
Actualizado 2019-07-07 14:40:49 UTC
Ver: 5921   Respuesta: 1
Doug Clark
Actualizado 2019-07-07 18:06:07 UTC
This isn’t AI!
Ver: 4969   Respuesta: 1
How to change zip code in the addres in the setting/controller
sorondo
Actualizado 2019-07-09 07:50:41 UTC
How to change zip code in the addres in the setting/controller?
By mistake I nitroduced a wrong zip code in the address of the controller... How can I change it? Do I have to remove the controller and inmediatelly to add a new one? Thanks.
Jcgc
Ver: 5299   Respuesta: 3
Spanish language for control
sorondo
Actualizado 2019-07-09 09:24:52 UTC
Jcgc
Ver: 4965   Respuesta: 1
Whisperer Test
Dan Leng
Actualizado 2019-07-10 18:29:27 UTC
Ver: 5353   Respuesta: 2
Rod Timby
Actualizado 2019-07-11 18:09:47 UTC
Ver: 4480   Respuesta: 0
Rod Timby
Actualizado 2019-07-11 18:14:39 UTC
Ver: 4578   Respuesta: 1
Actualizado 2019-07-12 15:05:29 UTC
Ver: 5284   Respuesta: 1
How do you stop the watering
Rick Jones
Actualizado 2019-07-13 16:02:14 UTC
Ver: 4622   Respuesta: 1
Netro + Netatmo
Luca Magnani
Actualizado 2019-07-14 07:42:29 UTC
Good morning
I have a netatmo weather station,
it would be nice to connect it to read the weather data precisely for my area.
Thank you in advance
Ver: 7606   Respuesta: 1
No light
Gilbert Lee
Actualizado 2019-07-14 15:37:53 UTC
Ver: 4788   Respuesta: 1
Location Based Watering Restrictions - Check-in Interval
Matt Grooms
Actualizado 2019-07-14 18:58:52 UTC
One of the great features of Netro is it's ability to look up my local (city/state) watering regulations, and apply them to my watering schedule. Bravo Netro!
Months ago, when I installed my Netro controller it looked up the then current (Stage-One) restrictions, and applied them to my watering schedule. However, since that time the watering restrictions have been eased (Year-Round restrictions) , and I'm allowed to water any day of the week. Well, Netro did not follow the changes and is still applying the old restrictions.
I attempted to trick Netro into rereading my local restrictions by turning the feature off, then back on. No luck.
So the questions are:
1) How often does a Netro Controller check the cloud database for updated watering restriction for it's location?
2) How often does Netro Central (you guys) check with communities for watering restriction updates and update your database so that deployed Netro controllers get accurate rules to apply?
I can see where it might be hard to keep up with small communities and rural areas, but my location (San Antonio, Texas, USA) has almost two-million people in the area. A single update on your part would provide a potentially large number of Netro users with current watering restriction information.
Matt
Ver: 7423   Respuesta: 1
HomeKit?
pintapass
Actualizado 2019-07-15 03:55:15 UTC
Ver: 5809   Respuesta: 3
Problems with the internet
Morrie Wayne
Actualizado 2019-07-15 16:50:35 UTC
We have a hot spot for our internet connection from Verizon. The hot spot keeps going off line and we don’t know what to do to correct it. Our Netro unit is in Florida and we are in Ohio. We don’t have any one close in Florida to help us with our problem. Might there be a inexpensive internet we might be able to acquire, or do you have another solution? We appreciate any suggestions you might have. We are happy with our Netro unit. Morrie Wayne. Address in Florida is. 1673 Abasco Ct. The Villages, Florida 32162. Address In Ohio is 18379 Squirrel Run Dr, Cleveland, Ohio 44130. My cell # is 440-856-9242. Thanks for any solution to our problems.
Ver: 5105   Respuesta: 2
Introducing the Referral Program
Actualizado 2019-12-10 03:02:22 UTC
To the Netro community:
We are pleased to launch the Netro Referral Program. You can earn reward points when your friends become Netro customers!
1.Invite your friends to join Netro using your unique link
2.Your friends get a discount or reward points
Your friends enjoy 10% off their first orders or $10 credits toward their first subscriptions.
3.Get your reward points and repeat to earn more
You will earn reward points* equivalent in value to the discounts or credits given to your friends.
*Reward points: for every US dollar your friends spend on their first orders you will earn 10 points ($0.1). You will earn 1000 points ($10) for every friend who chooses to subscribe. There are 3 ways to redeem the reward points:
1. Use the reward points to purchase Netro products at netrohome.com (100 points = 1 US dollar)
2. Use the reward points to pay for your subscription fee at netrohome.com (100 points = 1 US dollar)
3. Withdraw the reward points to your PayPal account (200 points = 1 US dollar)
Your reward points will never expire.
You can check more info about Netro's Referral Program here https://netrohome.com/shop/refer
Ver: 5450   Respuesta: 2
Water stops running before the cycle is over
sgschrank
Actualizado 2019-07-18 18:03:03 UTC
Recently I have been having issues with zones 5-8 stop watering before the cycle is over, but keeps counting down and moves to the next zone and does the same thing. I have tried resetting the unit, re-linking the wifi, but doesn't seem to make a difference. Help!
Ver: 4597   Respuesta: 0
