Alexa
Emilio Maione
Actualizado 2019-04-24 06:50:56 UTC
Ver: 4897   Respuesta: 1
Answers?
Howard Blankenship
Actualizado 2019-04-24 14:46:54 UTC
Ver: 4548   Respuesta: 1
Service account
ltanase13
Actualizado 2019-04-25 01:26:55 UTC
Ver: 4870   Respuesta: 1
One sensor for multiple zones
bdcfam
Actualizado 2019-05-01 01:28:20 UTC
Is there a way to assign one sensor to multiple zones?
Ver: 7563   Respuesta: 2
Connecting Hunter PVG-Valves
John Mayer
Actualizado 2019-05-01 15:57:37 UTC
I am trying to connect my Hunter PVG 101 GB valves to my new Metro Sprite.
I haven't installed a watering System before so I am quite a newbie here.
I have managed to set my Sprite up. But my valves aren't working.
I have double checked my wires. No issue there. As I am living in Germany I have bought my own power supply. It's this one: INNOVATE LED Trafo ECO 24 Volt/DC, 0-50W - LED Treiber - Transformator - Netzteil - Driver (24V - 50W) https://www.amazon.de/dp/B01AALEYR8/ref=cm_sw_r_cp_apa_i_LgCYCb2PT86Y9
Are there any recommendations, what I could do wrong?
Thanks so much,
Ver: 5407   Respuesta: 2
Graphs
Jim Bethea
Actualizado 2019-05-04 11:25:22 UTC
Ver: 4683   Respuesta: 1
John Locke
Actualizado 2019-05-05 14:16:12 UTC
Ver: 4981   Respuesta: 1
Henry
Actualizado 2019-05-06 19:40:59 UTC
same issue...
so what to do with it?
Ver: 5047   Respuesta: 2
is the Pixie faucet joint (both in and out) GHT (Garden Hose Thread) or NPT (National Pipe Thread)
Oliver Pettit
Actualizado 2019-05-09 01:33:23 UTC
Could you please confirm if the Pixie faucet joint is GHT (garden hose thread) or is it NPT (National Pipe Thread)?
I'm looking for adapters in Australia to use this unit and its unclear what the size/type the faucet is.
Ver: 5287   Respuesta: 1
Problemi con Google home
Max Point
Actualizado 2019-05-12 08:36:40 UTC
Massimo
Ver: 4843   Respuesta: 1
Actualizado 2019-05-14 07:01:36 UTC
Ver: 5558   Respuesta: 2
Manual mode fail to shut off
Actualizado 2019-05-16 02:05:13 UTC
Ver: 5075   Respuesta: 1
Whisperer stopped working
Pelle Fisk
Actualizado 2019-05-17 13:30:13 UTC
Ver: 5585   Respuesta: 2
Hot weather algorithm
Joshua Berk
Actualizado 2019-05-17 16:15:51 UTC
Ver: 5185   Respuesta: 2
Steven V
Actualizado 2019-05-18 13:08:55 UTC
Ver: 4717   Respuesta: 1
David Claridge
Actualizado 2019-05-18 13:21:53 UTC
Ver: 4737   Respuesta: 1
Dennis N
Actualizado 2019-05-18 17:52:30 UTC
Ver: 4653   Respuesta: 1
Roianne Cox
Actualizado 2019-05-19 13:52:50 UTC
Ver: 4636   Respuesta: 1
jpmeyer81
Actualizado 2019-05-19 15:04:11 UTC
Ver: 5051   Respuesta: 1
Manually skip next watering
Randy Ziffer
Actualizado 2019-05-19 16:47:13 UTC
Ver: 4905   Respuesta: 2
