Whisperer low battery alert
Jesus Sanguinetti
Actualizado 2025-07-19 15:24:34 UTC
Ver: 902   Respuesta: 1
Stefano
Actualizado 2025-07-21 21:17:23 UTC
Hi everyone,
I’ve already tried:
Thanks in advance!
– Stefano
Ver: 929   Respuesta: 1
Change zone order
Matt Ward
Actualizado 2025-07-22 00:43:18 UTC
Ver: 882   Respuesta: 1
Andrew Woods
Actualizado 2025-07-22 19:30:55 UTC
Ver: 877   Respuesta: 1
Issue with Netro Spark
Fabrice GOUFFRAN
Actualizado 2025-07-23 06:34:33 UTC
Ver: 891   Respuesta: 2
Spark not working – won’t start valves despite all attempts
Stefano
Actualizado 2025-07-23 06:55:23 UTC
Hi everyone,
I’ve been using a Netro Spark (8-zone model) for some time, but recently it stopped working properly.
The controller connects to Wi-Fi and appears online in the app, but when I try to start any valve (manually or via schedule), it says “communicating” and nothing happens.
  • Restarted the Spark multiple times
  • Performed a full reset (12 seconds on RST button)
  • Re-added the device in the app
  • Tried to trigger irrigation manually from both the app and the controller
  • Confirmed that the system works when I open the valves manually from the controller
  • Tried different power supplies
  • Connected to a mobile hotspot instead of my home Wi-Fi (same result)
  • Updated the firmware to the latest version (v3.3.0)
  • Purchased a brand new Spark controller and tested it — same exact issue
At this point, it looks like the issue is not hardware or network-related.
Could it be a firmware bug or a server-side problem?
Any help would be greatly appreciated!
Thanks in advance,
Stefano Mauri
Ver: 957   Respuesta: 3
Watering time
Andrew Gor
Actualizado 2025-07-23 14:36:45 UTC
I added the Netro whisperer 2 soil sensor to my ficus pot. The sensor gives me contradictory messages. It says that next watering should be in one week but every night it sends a notification to 'water the ficus sensor's. What should I do?
Ver: 911   Respuesta: 1
Interpretation of soil moisture readings by Whisperer
Missy Bartell
Actualizado 2025-07-26 12:13:30 UTC
I have two Whisperers that I move around to various parts of my graden to get comparative readings of sunlight and soil moisture.  I really do not know how to interpret the moisture readings which generally range from 50% to 98% but can be as low as 30%.  Soil type varies from a clayey loam to heavy clay.   How do I know when watering is required?  Does the meter measure the capillary water?  The adhered water?  The percentage of voids filled with water?  How does Netro calculate the percentage of water and what do the readings mean?
Ver: 383   Respuesta: 1
App reports off-line, controller is on-line and web based app is on-line
Jorge Rodrigues
Actualizado 2025-08-08 18:46:45 UTC
I have a strange situation:
- App reports controller as off-line, sometimes it reports on-line for brief periods. It was working fine till three days ago
- Controller has green light
- Web app on the netro site reports on-line and works
- The controller is watering
- The Wifi near the controller is working and I have not changed the password or settings
- I have tried forcing it to change the wifi, I get the bluetooth light and the controller is detected on the app via bluetooth, however it fails after I insert the password for the wifi. This is odd since the device is connected.
I suspect there is a synch issue between the App and your servers. Help would be appreciated.
Ver: 231   Respuesta: 1
Actualizado 2025-08-10 00:01:57 UTC
Ver: 219   Respuesta: 1
Problem: Spark 8 controller stuck on "in communication"
Stefano F
Actualizado 2025-08-10 07:01:41 UTC
Hi everyone,
I'm experiencing a serious issue with my Netro Spark 8 controller. It connects correctly to Wi-Fi and appears online in the app, but when I try to start irrigation manually, the app just stays on "in communication" and nothing happens.
Despite these attempts, the problem persists. I also tested the solenoids with a multimeter, and they’re working correctly. If I activate the valves directly from the controller, they respond as expected—so it’s clearly not a hardware issue.
I should also mention that I previously had the same problem with two Sprite6 controllers. That’s why I switched to the Spark 8, hoping it would solve the issue. Unfortunately, it hasn’t.
To make matters worse, scheduled programs aren’t working either.
This is an urgent situation because my plants are currently without water. I’d really appreciate any help or suggestions to resolve this.
Thanks in advance,
Stefano
Ver: 260   Respuesta: 2
Spark 16 works only in manual
Davide Riva
Actualizado 2025-08-11 21:55:04 UTC
Hello, I’ve installed netro app on my iPhone, followed the procedure to connect the spark 16 and everything is fine, but when I try to activate valves with the app, the led turn white.
If I remove spark 16 from the app, the led turn green and I can only activate valves from the controller,
Any solution?
Davide
Ver: 272   Respuesta: 2
Whisper not showing any moisture reading at all
Actualizado 2025-08-12 02:45:00 UTC
Why is Whisperer not showing any moisture reading at all? after working fine for days, it just stops sending moisture info
Ver: 243   Respuesta: 1
help Netro Spark 6
Andrea Giannelli
Actualizado 2025-08-14 09:03:33 UTC
Hi everyone,
Thenks
Ver: 252   Respuesta: 1
Pixie valve won’t close
Geoff Miller
Actualizado 2025-08-22 16:06:03 UTC
One, and only one ,of my 4 Pixies occasionally sticks in open mode, not closing the valve, watering until I notice it. It won’t shut down from button and I have to turn it off or remove battery to get it to reset. It works for a few days and happens again. It has been working well for about 6 months. Any ideas how to fix this?
Ver: 55   Respuesta: 0
New app (Android)
Ken Jennings
Actualizado 2018-06-08 16:39:10 UTC
Ver: 7001   Respuesta: 1
Great job Team!
robertj51
Actualizado 2018-06-11 17:43:40 UTC
This is a great product with a great application as well. Thanks to the team and the developers for working hard to make this right. This is fantastic!
Ver: 6225   Respuesta: 1
Weather override
U Koul
Actualizado 2018-06-15 17:39:02 UTC
Ver: 6318   Respuesta: 3
Subsoil Moisture-Netro app
Rick Priory
Actualizado 2018-06-16 13:09:48 UTC
Ver: 5809   Respuesta: 1
Soil type?
John Broadbent
Actualizado 2018-06-16 14:27:36 UTC
Ver: 7690   Respuesta: 2
