Skipped watering on calendar and the system still watered...
Daniel Schoonover
更新时间 2020-07-26 01:36:47 UTC
I noticed system was going to water this afternoon so I skied the watering on the calendar hours before.
When the time came the system still watered my yard?
Why?
And I could not find a single way to stop it.
浏览: 8446   回复: 1
Netro Sprite dead after 27 months (3 months post-warranty)
Doug Burkott
更新时间 2020-07-17 11:26:34 UTC
Has anyone had an issue with their Sprite being inoperable shortly after the warranty ended?  I tested the power prongs with a voltmeter and the controller is getting electricity, but no lights are on.   It's 105 deg in Austin and no rain in sight.  I'm going out of town for 5 days, so I'm in trouble.  I'm going to have to go to Home Depot to get something off the shelf installed today before my trip.
Anyone with the same problem?  Has anyone been successful with a claim outside of the warranty period?
Update:  The Sprite went offline at the same time the LED light stopped working.  The watering schedule resumed two days later and the LED was still off.  Meaning - Sprite works fine, LED doesn't work.  Netro told me to send the unit in over the winter and they will repair the LED.  Awesome - thanks Netro!
All the best,
-Doug
浏览: 9260   回复: 2
Offline sratusc
Andrea Del Ben
更新时间 2020-07-12 19:31:12 UTC
浏览: 8604   回复: 1
JanT
更新时间 2020-07-08 18:44:04 UTC
浏览: 8436   回复: 1
Jim Falvey
更新时间 2020-07-07 23:54:23 UTC
浏览: 8638   回复: 1
low water pressure
vic sabo
更新时间 2020-07-02 22:08:39 UTC
浏览: 8422   回复: 1
Power Cycle
Jorge Bastos
更新时间 2020-06-26 22:30:53 UTC
Any way to correct this?
Regards.
浏览: 8460   回复: 1
Mark Poppen
更新时间 2020-06-12 01:34:57 UTC
浏览: 8645   回复: 1
Watering program
Maciej Karpinski
更新时间 2020-05-18 01:01:57 UTC
浏览: 8761   回复: 1
alnavasa
更新时间 2020-05-08 20:36:44 UTC
Start ar 21:00 end at 3am
浏览: 10981   评论: 0
I want to increase watering time since it only says 2:00 minutes (it works for this time) but am unable to increase/change it. Please help. Please help!
Anne Knudsen
更新时间 2020-05-03 16:47:04 UTC
I can not change the time (number of minutes) for watering to happen. please help.
Two of the zones are 45 minutes and 60 minutes and they work.
浏览: 8582   回复: 1
Watering when zones are off
Ben Wojcik
更新时间 2020-05-02 13:07:30 UTC
I turned off all my zones, but my netro still stays is watering.  How do I get it to stop doing this?  I can't figure out what its watering either.
浏览: 9338   回复: 1
Problem with controling relay
Srdjan
更新时间 2020-04-26 06:54:18 UTC
Hi, i try to control working water pump by M contact on controler using relay(24VAC) and that is not posible, I try with three different relays and same situation.
Is anybody have same or similary problem and if anybody use M contact for controling relay please send tehnical data or picture of that releay that I can buy same... Suporrt not answering on this question I send them video of working two different relays but not got answer...
I tru to upload video here but that is not posible...
Thank for help.
浏览: 8599   回复: 1
Pixie Leaks
Rich Keith
更新时间 2020-04-19 17:18:48 UTC
浏览: 8663   回复: 1
Max V
更新时间 2020-04-17 09:46:19 UTC
浏览: 8842   回复: 1
Luca Manfrin
更新时间 2020-04-10 11:43:03 UTC
浏览: 9328   回复: 2
Seb Cruzer
更新时间 2020-04-07 15:03:43 UTC
hello,
Please help!
浏览: 9208   回复: 2
Luca Manfrin
更新时间 2020-04-07 09:33:03 UTC
浏览: 8881   回复: 1
Host mode
Luca Manfrin
更新时间 2020-04-06 17:55:38 UTC
What is host mode?
浏览: 9319   回复: 1
Casey S
更新时间 2020-04-05 19:41:30 UTC
浏览: 9094   回复: 1
