Ralph G
更新时间 2023-06-23 18:56:48 UTC
浏览: 7160   回复: 1
zoe
更新时间 2023-06-15 00:40:38 UTC
Linda Lundgren
浏览: 6993   回复: 1
No notifications
Khalid Mousa
更新时间 2023-06-14 03:25:18 UTC
浏览: 7379   回复: 1
Calibrating sprinkler output
SonDeMar
更新时间 2023-06-13 15:16:54 UTC
浏览: 7046   回复: 1
Delay settings
Roberto Pirovano
更新时间 2023-06-13 09:15:35 UTC
浏览: 7076   回复: 1
Certificate Expired - AGAIN!
AllenHome
更新时间 2023-06-11 06:42:24 UTC
浏览: 6769   回复: 1
Certificate error
ventinovesette
更新时间 2023-06-11 06:03:25 UTC
浏览: 7248   回复: 2
Problem with APP connection
Davide G.
更新时间 2023-06-11 05:49:55 UTC
浏览: 7160   回复: 2
Change Country
samhye
更新时间 2023-06-08 12:58:01 UTC
Hello all,
Many thanks.
浏览: 6926   回复: 1
2 zones not working
Shahid Habib
更新时间 2023-06-05 13:39:04 UTC
Any help will be appreciated.
浏览: 7450   回复: 3
Rename device
3 Dorset Lake Avenue
更新时间 2023-05-28 09:51:48 UTC
浏览: 6749   回复: 1
Gestione ritardi
Stebel
更新时间 2023-05-28 04:44:07 UTC
浏览: 6989   回复: 1
Zone invert
Stebel
更新时间 2023-05-28 04:42:47 UTC
浏览: 6936   回复: 2
Can I back up my Netro?
Jacob Matheny
更新时间 2023-05-26 15:39:56 UTC
浏览: 7189   回复: 1
Jacob Matheny
更新时间 2023-05-26 15:39:51 UTC
浏览: 7067   回复: 0
Strange watering cycle
Joe Mariano
更新时间 2023-05-22 14:40:16 UTC
浏览: 7009   回复: 1
Mismatch zones/times
Jose R
更新时间 2023-05-21 12:40:53 UTC
So happy with how this works.
浏览: 6688   回复: 1
Richard Nibbler
更新时间 2023-05-17 02:50:09 UTC
Tyvm
浏览: 7333   回复: 3
Whisperer wifi connection
Jim Shields
更新时间 2023-05-15 21:20:33 UTC
浏览: 6766   回复: 1
Paolo S
更新时间 2023-05-12 15:41:24 UTC
Any suggestion?
Any issue with iphone 14?
浏览: 7090   回复: 1
