Steve M
更新时间 2024-06-30 23:53:31 UTC
浏览: 6729   回复: 1
Adjusting for tree cover
Steve M
更新时间 2024-06-30 23:47:30 UTC
浏览: 6684   回复: 1
app crashing
Christoforos
更新时间 2024-06-28 14:13:56 UTC
Can you please help.
Christoforos
浏览: 6707   回复: 1
Where is the documentation on how to use the app?
Lance Blaise
更新时间 2024-06-20 03:41:17 UTC
Where is the documentation on how to use the app? I have no clue how to set my own schedule or how to use the smart scheduling... I can't find anything on how to use this app at all and it's pretty confusing. I am looking at the app and it seems to have smart watering enabled, but there are times where it's skipping 3 days randomly and there is no rain that is supposed to take place on those days, so no clue why it's skipping those days. Can someone direct me to where the documentation is for using the app?  Thank you.
浏览: 6742   回复: 1
network error
更新时间 2024-06-18 10:24:07 UTC
i have a Netro app
on ios with a 12 station
Starting this morning i receive a
Network error message
i restarted/ re connect
same message
May i need a new firmware ?
浏览: 7506   回复: 3
Change whisperer mode
Jure
更新时间 2024-06-15 11:33:22 UTC
What is the proper way for changing Whisperer from standalone mode to adding it to my Netro Pixie or Sprite?
浏览: 6796   回复: 1
Where to see Whisperer data collected in the Netro App ?
JDo REY
更新时间 2024-06-07 09:01:29 UTC
Where to see Whisperer data collected in the Netro ?
浏览: 6812   回复: 2
Rainbird R Van rotator
更新时间 2024-06-04 19:09:06 UTC
Hi there
浏览: 7313   回复: 3
Shut off one zone
Wil
更新时间 2024-05-31 04:05:40 UTC
浏览: 6908   回复: 2
Javier NM
更新时间 2024-05-26 06:32:56 UTC
浏览: 7246   回复: 1
PREFERRED ARTICLES
Javier NM
更新时间 2024-05-12 06:36:42 UTC
浏览: 7353   回复: 1
Help!
John Zuzula
更新时间 2024-05-02 14:46:09 UTC
浏览: 7030   回复: 1
Manual operation doesn’t stop
Ciro Bracciante
更新时间 2024-04-29 11:31:14 UTC
浏览: 6686   回复: 1
App Netro
Antonio Cordon Rodriguez
更新时间 2024-04-28 09:28:48 UTC
浏览: 6687   回复: 0
Fabio F
更新时间 2024-04-20 14:28:45 UTC
 How do I solve this problem?
浏览: 7493   回复: 4
Bob Cohen
更新时间 2024-04-15 23:49:36 UTC
浏览: 7068   回复: 2
Exclamation on Schedule
Oilol
更新时间 2024-04-10 12:56:31 UTC
Thanks in Advance!
Tim
浏览: 6907   回复: 1
2 whisperer to 1 pixie
Paolo S
更新时间 2024-04-02 20:28:39 UTC
浏览: 7340   回复: 1
Forecast doesn't show
Edan Manos
更新时间 2024-03-31 05:34:57 UTC
浏览: 6842   回复: 1
Manual Operation
Mario Hardy
更新时间 2024-03-21 12:47:06 UTC
浏览: 7114   回复: 1
