Joshua Berk
更新时间 2018-10-10 06:22:09 UTC
浏览: 10042   回复: 3
Disable all zones for winter
Wayne White
更新时间 2018-10-09 23:05:21 UTC
It’s winter, I have manual zones and 3 sprites. Is there a way to disable the sprites? There has to be. A simple switch I’m missing.
浏览: 9325   回复: 1
App Crashesdevice
Aaron Miller
更新时间 2018-09-16 11:28:35 UTC
The app crashes on android phone (S8) when attempting to set rain preferences. This is annoying. None of my messages regarding this have been answered by tech support. Perhaps I should return the device and get a Rachio?
浏览: 8948   回复: 0
Netro app not work
Rodrigo Echeverria
更新时间 2018-08-31 20:40:48 UTC
with the new update ios 11.4.1 does not work. the app starts and then stops working,
resets itself
浏览: 9952   回复: 1
Historical usage
sihler
更新时间 2018-08-20 23:38:11 UTC
Is there a way to see raw historical water usage in time per zone?
浏览: 9838   回复: 1
Redwood pine tree
Javier Gutierez
更新时间 2018-08-08 18:32:32 UTC
Hello. I'm setting a zone in where i have to water Redwood pine trees. I was looking for them under the species/type. I can't find it. I tried different names, species, etc. I believe it's not available yet.
Please, could you help me with:
Letting me know which tree available within the app will be more suitable to cover Redwood pine tree needs
Updating, if it is possible, the trees list available in the app
Thanks in advance.
浏览: 9822   回复: 1
Accuracy of dark sky in Canada
更新时间 2018-07-31 03:16:54 UTC
The dark sky android app is not available in Canada  so I wonder how accurate their weather is here.  To try and determine this for myself, I looked at the netro temperature graph..  Today it is 34C at my house  but the temperature summary graph in  Netro says it is only 22C. (for my friends still using Fahrenheit that is about a 24F difference )  Does anyone know when Netro gets the temperature that it uses in the graph? Other thoughts on dark sky accuracy in Canada?
浏览: 10651   回复: 1
Netro and Alexa
更新时间 2018-07-30 22:29:36 UTC
I've loaded the Alexa skill for Netro. When I tell Alexa to ask Netro to water a zone, it just looks up references for "metro" instead. Much as I appreciate Alexa looking up train schedules for me, I'm curious if others have had this problem.  I've tried pronouncing  it "net row" and "neat row" but  neither gets recognized.
This isn't a critical issue, as I'm not sure I would ever see the point in voice control over my sprinklers  but thought I would set it up to try anyway
浏览: 10738   回复: 1
Netro app fails to run
Duncan Krause
更新时间 2018-07-29 17:50:52 UTC
Any ideas
浏览: 10528   回复: 1
Manual Watering
Steve
更新时间 2018-07-10 17:54:41 UTC
浏览: 11651   回复: 2
Scheduling
Richard Hall
更新时间 2018-07-09 15:56:46 UTC
浏览: 10459   回复: 1
Subsoil Moisture-Netro app
Rick Priory
更新时间 2018-06-16 13:09:48 UTC
浏览: 10612   回复: 1
Weather override
U Koul
更新时间 2018-06-15 17:39:02 UTC
浏览: 11470   回复: 3
New app (Android)
Ken Jennings
更新时间 2018-06-08 16:39:10 UTC
浏览: 12403   回复: 1
