Random Manual Start
Mario Hardy
Actualizado 2023-07-13 04:53:04 UTC
How to make this stop???
Ver: 3871   Respuesta: 1
sellet
Actualizado 2023-07-13 16:20:23 UTC
Ver: 3653   Respuesta: 1
Problème de localisation
Yoann Lienard
Actualizado 2023-07-16 10:54:55 UTC
Bonjour ,
Comment faire ?
Merci de votre réponse.
Yoann
Ver: 3534   Respuesta: 1
Watering even when it's wet
Jure
Actualizado 2023-07-16 14:14:17 UTC
Ver: 3891   Respuesta: 1
Weather underground
Dion Friedt
Actualizado 2023-07-17 03:09:10 UTC
Ver: 3492   Respuesta: 1
Preferences about time
Paolo Vecchi
Actualizado 2023-07-17 07:41:39 UTC
Ver: 3578   Respuesta: 1
Andrea Vecchia
Actualizado 2023-07-17 14:34:51 UTC
Ver: 3560   Respuesta: 1
Not calculating for ecomode?
Melissa N
Actualizado 2023-07-20 05:42:48 UTC
How can I fix this?
Ver: 3394   Respuesta: 1
ALGORITHM FLOW RATE
Javier NM
Actualizado 2023-07-20 07:08:54 UTC
Ver: 3918   Respuesta: 1
Mirko Zen
Actualizado 2023-07-21 09:35:33 UTC
Ver: 3407   Respuesta: 1
Actualizado 2023-07-24 00:54:03 UTC
Ver: 3842   Respuesta: 1
misterhoff
Actualizado 2023-07-25 03:11:25 UTC
Ver: 3459   Respuesta: 0
Feature request update
Actualizado 2023-07-25 06:11:19 UTC
Ver: 3796   Respuesta: 1
Netro - Stopped Working and won’t power up
John Loethen
Actualizado 2023-07-25 14:04:38 UTC
Been a Netro customer for a while and pretty handy. I have three different Netro controllers and my oldest one just stopped working and won’t power up… I have verified the power at the outlet and have changed out the power supply with another 24v power supply that I know works. Still the controller will not power up.
Let me know if anyone else has suggestions.
John in Lincoln, NE
Ver: 3583   Respuesta: 1
Netro Sprite 6 valve won’t stop
Alberto Casu
Actualizado 2023-07-29 19:25:45 UTC
I just replaced my sprinkler controller with a new Netro Sprite 6.
Using both a programmed or a manual start, all valves don’t stop unless I remove power to the Sprite.
During a program, where I planned the zones to run sequentially, the zones activate one after the other without stopping and causing the zones to loose pressure and be unable to complete.
On the FAQ, it says to remove power to stop the zone, which actually stop all the watering, but this it totally unusable to me.
I am using the European version with the provided power supplier. I am based in Italy.
Can you please help?
Ver: 3998   Respuesta: 2
Netro phone app won't open
Christopher Scarborough
Actualizado 2023-07-30 23:32:37 UTC
Tim Quach
Actualizado 2023-08-01 08:02:49 UTC
Ver: 3525   Respuesta: 1
Atif Siddiqui
Actualizado 2023-08-02 04:51:58 UTC
Using Bootlace ferrules.
Bob Howard
Actualizado 2023-08-03 06:36:09 UTC
I'd like to use bootlace ferrules for all the wiring to the sprite as shown in your installation video (power connection). I'm using 0.5mm² x 7 core cable and 0.5mm² bootlaces and the unit won't grip them. I've tried other sizes with the same result. What size ferrule is required?
Ver: 4328   Respuesta: 1
Date format
Bob Howard
Actualizado 2023-08-03 23:27:42 UTC
Ver: 3864   Respuesta: 1
