Network error
Sadar Yacob
Actualizado 2022-11-25 15:04:34 UTC
Ver: 4281   Respuesta: 2
Defective Whisperer
Actualizado 2022-11-26 10:04:00 UTC
Ver: 3841   Respuesta: 1
Orders page shows an error page
Richard
Actualizado 2022-12-03 04:57:33 UTC
The Netro Account Order page only displays:
instead of the orders.
I have two orders in the system but cannot see the status of either of them.
Ver: 4126   Respuesta: 2
Roberto Felici
Actualizado 2022-12-11 13:25:10 UTC
Ciao!
Why?
Tx for your help
Ver: 4201   Respuesta: 1
Roberto Felici
Actualizado 2022-12-11 13:31:01 UTC
Ciao!
Tx!
Ver: 3534   Respuesta: 1
Noam Leshem
Actualizado 2022-12-15 22:29:40 UTC
Ver: 4204   Respuesta: 2
Irrigazione incontrollata
Martina Brasesco
Actualizado 2022-12-22 15:13:34 UTC
Salve,
Ver: 3477   Respuesta: 1
So complicated to get your product from France
Actualizado 2022-12-25 08:01:47 UTC
I purchased a Netro sensor about one month ago at NetroEU shop through Amazon and got no news about my delivery. I remember it was also a bit complicated to get this Netro sensor the first time I ordered it due to taxes that significantly increased the price.
What is the best way to get your products ? I am really fond of these latter but a bit upset it is so a big deal to get them.
If you have solution it would be great.
Ver: 3754   Respuesta: 1
Actualizado 2022-12-26 09:03:17 UTC
Ver: 3709   Respuesta: 1
Andrew
Actualizado 2022-12-29 21:38:22 UTC
Ver: 3758   Respuesta: 3
Green Peas
Actualizado 2023-01-01 18:34:14 UTC
Ver: 3734   Respuesta: 2
Home Assistant
Jens Wymeersch
Actualizado 2023-01-12 09:25:04 UTC
Ver: 4320   Respuesta: 2
Customized moisture level not triggering watering
Richard
Actualizado 2023-01-12 21:29:59 UTC
I have a Sprite with 3 Whisperers, all in the veggie patch.
I have the zones set to customize with a low of 25% and a high of 45% (I find 30 - 35 % moisture about right)
But the zones just won't get watered!
Zone 1 is down to 6% today and has been dropping steadily for days.
I HAVE to manually water, as the day time temperatures are consistently over 30 degrees (today 33, tomorrow 37).
Otherwise the plants will die.
Given there are only two values to enter (low and high). How do I stop the Netro from skipping days and putting the zones in the "Moisture" category??
Ver: 3789   Respuesta: 1
Change Username
Casa Luna
Actualizado 2023-01-13 10:08:35 UTC
Is it possible?
Thanks in advance :)
Ver: 3323   Respuesta: 1
Delay on Manual watering
Jim Barnes
Actualizado 2023-01-22 01:22:58 UTC
Why is it when I select a manual watering it delays until wake up?
Ver: 3589   Respuesta: 1
Reduce watering time in 1 zone
Ale Levi
Actualizado 2023-01-22 19:32:59 UTC
Hi, I'd like to reduce the watering time in 1 zone which gets dumped each time Netro waters. The other zones are ok. Is there a way to do that in the smart mode? Maybe set an offset for that specific zone?
Ver: 3355   Respuesta: 2
andrew58
Actualizado 2023-01-25 08:49:48 UTC
Ver: 3321   Respuesta: 1
Jim Barnes
Actualizado 2023-01-25 13:36:55 UTC
Please help!!!
Ver: 3713   Respuesta: 2
Whisperer plant sensor
Vincent Coutinho
Actualizado 2023-01-26 20:56:14 UTC
How do you find the sensor battery percentage on the netro app.
Ver: 3622   Respuesta: 1
Help
Vũ Trần
Actualizado 2023-01-30 07:35:09 UTC
Ver: 4931   Respuesta: 3
