Rebekah H
更新時間 2018-11-28 04:23:43 UTC
瀏覽: 9974   回覆: 1
Joshua Berk
更新時間 2018-10-10 06:22:09 UTC
瀏覽: 10491   回覆: 3
Disable all zones for winter
Wayne White
更新時間 2018-10-09 23:05:21 UTC
It’s winter, I have manual zones and 3 sprites. Is there a way to disable the sprites? There has to be. A simple switch I’m missing.
瀏覽: 9781   回覆: 1
App Crashesdevice
Aaron Miller
更新時間 2018-09-16 11:28:35 UTC
The app crashes on android phone (S8) when attempting to set rain preferences. This is annoying. None of my messages regarding this have been answered by tech support. Perhaps I should return the device and get a Rachio?
瀏覽: 9398   回覆: 0
Netro app not work
Rodrigo Echeverria
更新時間 2018-08-31 20:40:48 UTC
with the new update ios 11.4.1 does not work. the app starts and then stops working,
resets itself
瀏覽: 10434   回覆: 1
Historical usage
sihler
更新時間 2018-08-20 23:38:11 UTC
Is there a way to see raw historical water usage in time per zone?
瀏覽: 10288   回覆: 1
Redwood pine tree
Javier Gutierez
更新時間 2018-08-08 18:32:32 UTC
Hello. I'm setting a zone in where i have to water Redwood pine trees. I was looking for them under the species/type. I can't find it. I tried different names, species, etc. I believe it's not available yet.
Please, could you help me with:
Letting me know which tree available within the app will be more suitable to cover Redwood pine tree needs
Updating, if it is possible, the trees list available in the app
Thanks in advance.
瀏覽: 10267   回覆: 1
Accuracy of dark sky in Canada
更新時間 2018-07-31 03:16:54 UTC
The dark sky android app is not available in Canada  so I wonder how accurate their weather is here.  To try and determine this for myself, I looked at the netro temperature graph..  Today it is 34C at my house  but the temperature summary graph in  Netro says it is only 22C. (for my friends still using Fahrenheit that is about a 24F difference )  Does anyone know when Netro gets the temperature that it uses in the graph? Other thoughts on dark sky accuracy in Canada?
瀏覽: 11077   回覆: 1
Netro and Alexa
更新時間 2018-07-30 22:29:36 UTC
I've loaded the Alexa skill for Netro. When I tell Alexa to ask Netro to water a zone, it just looks up references for "metro" instead. Much as I appreciate Alexa looking up train schedules for me, I'm curious if others have had this problem.  I've tried pronouncing  it "net row" and "neat row" but  neither gets recognized.
This isn't a critical issue, as I'm not sure I would ever see the point in voice control over my sprinklers  but thought I would set it up to try anyway
瀏覽: 11180   回覆: 1
Netro app fails to run
Duncan Krause
更新時間 2018-07-29 17:50:52 UTC
Any ideas
瀏覽: 10991   回覆: 1
Manual Watering
Steve
更新時間 2018-07-10 17:54:41 UTC
瀏覽: 12097   回覆: 2
Scheduling
Richard Hall
更新時間 2018-07-09 15:56:46 UTC
瀏覽: 10905   回覆: 1
Subsoil Moisture-Netro app
Rick Priory
更新時間 2018-06-16 13:09:48 UTC
瀏覽: 11068   回覆: 1
Weather override
U Koul
更新時間 2018-06-15 17:39:02 UTC
瀏覽: 11973   回覆: 3
New app (Android)
Ken Jennings
更新時間 2018-06-08 16:39:10 UTC
瀏覽: 12947   回覆: 1
