Product
What if the hose faucet is fully shaded and there is no sunlight to charge the battery of the timer?
Option 1. Add an additional hose between the faucet and the timer so that you can place the timer at a location where sunlight is available
Option 2. Lower the sync frequency in the app to reduce the power consumption
1. Press the power button for 3 seconds to turn on the timer. If the timer is already on, skip this step
2. Wait for 30 seconds. The LED light will become green (WiFi connected) or red (WiFi unconnected). If the LED light flashes in red and turns off shortly, the battery needs to be charged
3. Press the button again and hold for 12 seconds
4. The LED light should start to blink in white color
Wi-Fi Connection
If you are adding a new timer, please log into the Netro app, click on the plus sign and then follow the steps to connect it to your home WiFi network. If you have added the timer previously and are trying to reconnect it to your home WiFi network, you can find the setup by opening your Netro app, going to Settings, then select Timer, and then select "Change Wifi network/password" under the Network sub-heading.
To ensure a successful connection, please take the timer inside and be close to the WiFi router.
Make sure you have already followed instructions to connect the timer to your home WiFi when it is close to the WiFi router
1. Take the timer outside to the faucet. Press the power button for 3 seconds to turn on the timer. If the timer is already on, turn it off first by pressing the power button for 3 seconds
2. The timer will try to connect to the router
3. Wait for 15-30 seconds
4. If the connection is successful, the LED light will turn green
5. If the connection is unsuccessful, the LED light will turn red. You might need to move the timer closer to the router or add a WiFi extender
In the Netro app, please go to Settings->Timer, press "Change WiFi network/password" and follow the instructions.
User Watering/Actions
From the app: Go to the home screen. Find the white area, and then tap on the time. This allows you to change the watering duration. After that, you hit play to start a manual run. When the timer is sleeping, the manual run will start when the timer wakes up.
From the timer: Press the power button for 3 seconds to turn on the timer. If the timer is already on, skip this step. Wait for 30 seconds. The LED light will become green (WiFi connected) or red (WiFi unconnected). If the LED light flashes in red and turns off shortly, the battery needs to be charged. Press the button twice quickly to turn on the water. To turn off the water, quickly press the button twice again
