Tim Foster
Lives in: Conkal, Yucatán, MX
Using: SPRITE-12 , WHISPERER
Growing: Manila grass, Zeon Zoysia Grass
Questions
Soil Types
11
Tim Foster
Updated at 2019-12-14 13:28:44 UTC
Topic: Netro App
The app asks me to define my soil type and gives me a small list to choose from. I'm no gardening expert by any means and so I'm not really sure I've got this right. I selected the most draining type based on nothing more that guesswork really. We're in Yucatán, México so the entire area is limestone rock, but this website (https://sites.google.com/site/soilsoftheyucatanpeninsula/soil-types) gives more detail about the soil types in Yucatán. All this has done though is confuse me more.
Is there any reliable way that I can determine my soil type in Netro? The website says it's likely to be one (or a combination) of Gleysols, Histosols, Vertisols, Solonchaks, Leptosols, and Cambisols
Watering
11
Tim Foster
Updated at 2019-12-14 13:23:21 UTC
Topic: Smart Watering
I have my first period of rain coming up, so the smart schedule isn't planning on watering until Christmas Eve. Since getting the sensors working properly I've been very happy with the smart watering, but the rain predictions here tend to be a bit sketchy. As my system is saying it won't water because there is rain expected, does it automatically adjust itself and water if the predicted rain doesn't arrive?
Also, I have it set to not water if expected rain is 5mm. What is the difference in this context between expectation and forecast?
11
Tim Foster
Updated at 2019-12-05 17:56:44 UTC
Topic: Troubleshooting
Can't add new managers
11
Tim Foster
Updated at 2019-12-03 20:00:25 UTC
Topic: Netro App
Installation Direct to pump
11
Tim Foster
Updated at 2019-10-03 11:23:32 UTC
Topic: Installation
I have the following:
Whisperer seems wrong
11
Tim Foster
Updated at 2019-09-22 15:02:12 UTC
I only got my system delivered yesterday, so this could be something that I doing wrong, I have one whisperer in the back garden and one in the front. I live in Merida Yucatan and so it's hot all the time. The whisperer in the back is in direct sunlight most of the day yet it's reporting the temperature as 24. The one in the front is shaded by the house yet that is reporting 33. Both seem to be reporting incorrect moisture levels in both the topsoil and subsoil. Yucatán drains through stone to underground water sources so I would expect both topsoil and subsoil to be showing very arid.
Can anyone advise?
