Lives in: Madera, CA, US
Using: SPARK-16
Growing: Bermuda, Grape Vine
Questions
3
Updated at 2025-10-08 13:12:52 UTC
Topic: Smart Watering
3
Updated at 2025-08-10 00:01:57 UTC
Soil moisture adjustment
3
Updated at 2023-09-12 01:34:23 UTC
3
Updated at 2023-07-24 00:54:03 UTC
Topic: Troubleshooting
Netro weather
3
Updated at 2022-08-10 15:48:18 UTC
Topic: Netro App
3
Updated at 2022-07-26 05:14:15 UTC
3
Updated at 2022-07-15 12:27:12 UTC
3
Updated at 2022-05-23 14:33:07 UTC
Topic: Watering Restriction
3
Updated at 2022-05-21 17:31:03 UTC
Topic: Netro App
3
Updated at 2019-07-12 15:05:29 UTC
3
Updated at 2019-07-01 16:32:17 UTC
