Lives in: Washington, DC, US
Using: PIXIE-1
Growing: Tomatoes, Eggplant
Questions
Default rain settings
43
jbart65
Updated at 2020-05-12 21:31:24 UTC
Topic: Connected Home
Best sync option?
43
jbart65
Updated at 2020-04-22 02:56:17 UTC
Keep Connected option
43
jbart65
Updated at 2020-04-17 17:38:10 UTC
The particulars:
Which Alexa app?
43
jbart65
Updated at 2020-04-16 20:00:55 UTC
Jeffry
