Main feeder line shutoff valve control
Richard Miles
更新時間 2022-10-10 02:16:36
My main water line to the sprinkler system came loose and flooded my vacation home yard with 250,000 gallons of water before the leak was discovered and repaired.  Does Netro have the ability to control an electric valve on this feeder line such that the main valve will only open when the irrigation system calls for water?
瀏覽: 2807   回覆: 1
Mulch impact on duration
John Wright
更新時間 2022-09-13 12:58:29
瀏覽: 2835   回覆: 1
更新時間 2022-09-10 12:26:33
瀏覽: 2921   回覆: 1
How many rain sensors?
Roland Pircher
更新時間 2022-09-01 17:53:32
瀏覽: 2670   回覆: 1
Error in watering ?
Davide M.
更新時間 2022-08-29 11:31:56
Please help me:
  1.  what should I trust ?
APP:
WEB:
瀏覽: 2996   回覆: 1
rbrodt
更新時間 2022-08-25 16:29:00
瀏覽: 2915   回覆: 1
texan4ever521
更新時間 2022-08-24 20:24:11
My settings :
soil type: clay
sprinkler type: rotor head
shade: none or some shade
瀏覽: 3092   回覆: 1
Can Pixie measure water flow?
更新時間 2022-08-23 14:09:01
瀏覽: 2887   回覆: 1
Joshua Dunn
更新時間 2022-08-16 11:00:28
瀏覽: 2741   回覆: 1
1 or 2 frames
更新時間 2022-08-14 20:56:59
瀏覽: 3105   回覆: 2
scottsleight
更新時間 2022-08-08 21:41:10
瀏覽: 3011   回覆: 1
Douglas Ely
更新時間 2022-08-02 10:30:54
瀏覽: 3104   回覆: 1
Consistently underwatering
Douglas Ely
更新時間 2022-08-02 10:14:34
瀏覽: 3142   回覆: 1
Wrong scheduling?
Carlos Jimeno
更新時間 2022-07-30 07:49:09
Any ideas to solve it?.
Thank you very much.
瀏覽: 2717   回覆: 1
更新時間 2022-07-26 05:14:15
瀏覽: 3060   回覆: 2
Whisperer and Rachio
Billy Clark
更新時間 2022-07-25 19:19:29
瀏覽: 2557   回覆: 0
Erroneous "smart" scheduling
更新時間 2022-07-25 18:57:45
瀏覽: 2963   回覆: 1
更新時間 2022-07-15 12:27:12
瀏覽: 3234   回覆: 2
Pixie water pressure
Chris
更新時間 2022-07-15 09:03:05
瀏覽: 2666   回覆: 1
Waters excessively
Cindy Luvender
更新時間 2022-07-14 16:38:38
瀏覽: 2901   回覆: 1
