更新時間 2018-12-13 07:48:53 UTC
Burning Bush
Fragrant Sumac
Japanese Yew
California Lilac
Creeping Juniper
Dwarf Forsythia
Snowberry
Siberian
Carpet Cypress
瀏覽: 8251   評論: 1
Instructions about Replacing Hunter System
更新時間 2019-03-20 08:08:36 UTC
Replacing Hunter system
This page lists some instructions about replacing the common types of Hunter system with Netro smart watering controller.
Example 1:
To replace this controller with Netro smart watering controller, please follow the instructions.
The white wires are the common wires which should be connected to the C slots in Netro. Then the zone wires (1,2,3, .. 12) are directly mapped to the 1, 2, 3 .. 12 slots in Netro. The last step is to connect the power (the ground wire is not needed for Netro) then you should be good to go. The power adapter wires are the 2 yellow wires on the left side.
The green one below the yellow wires is the ground wire which is not needed for Netro.
The copper wires are rains sensors which are not needed for Netro either because Netro gets the weather information from WiFi network.
Example 2:
For this system, please connect the white wire to any one of the C slots in Netro. You can leave the M slot of Netro smart watering controller and one of the C slot unconnected.
The last step is to connect the power. The power adapter wires are the 2 yellow wires on the left side.
SEN are rains sensors which are not needed for Netro either because Netro gets the weather information from WiFi network.
Example 3:
Please connect the white wire to any one of the C slots in Netro. You can leave one of the C slot unconnected.
This system has 3 wires which connects to 24v lines. To replace it with Netro smart watering controller, you can use the existing 24V power(the yellow wires) for your Sprite. It looks like the thinner 2 are the ones but you might just want to try them on Sprite. Or you can use a voltage meter to determine.
If the thinner yellow wires turn out to be the power, than I think the thinner white wire is the common wire which should go to the C slot in Sprite.
Example 4:
You should connect the white wire(currently on RS) to one of the C slots in Sprite.
You do not need to connect the black wire(currently on C) and the brown wire(currently on RS). RS terminal is the rain sensor. Therefore, you do not need to connect these wires.
Example 5:
The white wire is the common wire which should be connected to one of the C slots in Netro. The power adapter wires are the 2 black wires on the left side.
Example 6:
The white wires is the common wires which should be connected to one of  the C slots in Netro. The power adapter wires are the two black wires on the left side.
The green one below is the ground wire which is not needed for Netro.
You do not need to connect the rain sensors because Netro get the weather forecast through WiFi.
Example 7:
You do not need to connect the blue one (remote). You can just leave it dangling but please use the tape to cover the metal head. The remote feature in Sprite is through the WiFi.
I am not sure about the red and white one. These are the two AV power wires. Normally there is only one wire for AC1 and one wire for AC2. In your case, it looks like the AC power is also sent to another device. The safest way to handle this is to keep this original connection. You might want to "noodle" the wires and insert them into the two "24 VAC" slots in Sprite. Please check out this connector for wire junctions:
https://www.amazon.com/Gardner-Bender-25-AWC-Assortment-Resealable/dp/B000F5TTE8
瀏覽: 22742   評論: 24
Instructions about Replacing Rainbird System
更新時間 2019-03-20 08:06:44 UTC
Replacing Rainbird system
This page lists some instructions about replacing the common types of Rainbird system with Netro smart watering controller.
Example 1:
 The common wires which should be connected to the C slots in Netro.
The Sprite controller does not need the ground wires. It does not need the rain sensor either. You can leave the M slot unconnected.
Example 2:
The COM wire goes to any C slot in Sprite.
The M slot will be empty because you do not have master valve.
The two red wires on the left go to the two 24 VAC slots.
Others are straightforward.
Example 3:
1. the COM wire in RainBird go to any of the C slots in Netro
2. The 1-6 zone wires in RainBird go to Slot 1-6 in Netro
3. Use the power adapter coming with the package for Netro
Other wires you can disregard them.
Example 4:
12(blue) and 11(red) go to the two AC slots on the right side for Netro. 10(white) goes to any one of the C slot in Netro. 9(black) goes to the M slot in Netro. 8-1(red) go the ZONES in Netro. You can leave the green wire (GND) open. The two leads from the power adaptor go to the two AC slots.
瀏覽: 10777   評論: 0
Instructions about Replacing Orbit System
更新時間 2019-03-20 08:07:49 UTC
Replacing Orbit system
This page lists some instructions about replacing the common types of Orbit system with Netro smart watering controller.
Example 1:
 Replacing Orbit model with Netro (model 57114-WT2X 4 stations)
You have 2 common wires and you can insert them into the 2 C slots in the Sprite controller.
You have 4 zones and you can use the 1-4 slots in Sprite to connect the 4 zone wires.
The last step is to hook up the 2 power wires using the Netro power adapter.
瀏覽: 8781   評論: 0
更新時間 2019-03-19 04:52:48 UTC
瀏覽: 6928   評論: 0
更新時間 2019-06-05 01:59:12 UTC
To the Netro community:
瀏覽: 375516   評論: 24
更新時間 2019-07-29 03:11:08 UTC
Add or delete users
 Access rights of shared users
Manager’s access rights:
Player’s access rights:
瀏覽: 9416   評論: 4
Emilio Maione
更新時間 2019-04-25 15:49:02 UTC
瀏覽: 8437   評論: 2
更新時間 2018-06-04 12:37:29 UTC
1.Year One
3.After the first week or so
4.Years Two to Three
5.After Year Three
Helpful Tips
Before you water:
瀏覽: 9879   評論: 4
Fixing App "Contact Us" feature not working for Andorid
更新時間 2019-07-15 01:37:42 UTC
To the Netro android users,
Our Netro app crashes for android on sending messages though Settings->Support->Contact Us suddently. Our R&D are fixing this issue and we expect to have the fixes in place in a few days. We are sorry about the inconvenience.
If you have any questions, please write to us support@netrohome.com and we will make sure to deliver technical support in short time.
Thanks again for your support and trust.
瀏覽: 6473   評論: 0
Netro on Apple Watch
更新時間 2019-08-07 06:39:26 UTC
2.Rainfall adjustment
瀏覽: 49434   評論: 15
Plant Sensors Monitoring Multiple Zones
更新時間 2019-08-07 06:39:15 UTC
We recently have launched an update for the Netro app on App Store and Google Play. In the newest version of the app, we allow one sensor to monitor up to 3 zones but the user needs to make sure the zones have similar environmental conditions.
Please upgrade your app to the newest version and go to Settings->Sensors, select a sensor, go to Zones and select the zones you would like to monitor.
After saving the changes, you can go to the Home page and check the topsoil moisture level of your zones reported by sensor.
Please feel free to explore other new and exciting features that we just added :
1.Support Apple Watch
(only available for iOS )
2.Support Weather Underground PWS
3.Rainfall adjustment
瀏覽: 6870   評論: 3
更新時間 2019-12-25 01:46:02 UTC
To the Netro Community,
瀏覽: 7529   評論: 0
How to replace an old controller with more than 12 zones
更新時間 2019-11-06 09:20:19 UTC
If your old controller has more than 12 zones, you will need to have 2 Netro controllers to replace it. Please follow the diagram below to safely wire the 2 controllers:
Now you can use the 2 C slots for the common wires and the 2 sets of 1-12 slots for the zone wires. If you do not have a master valve or pump, just ignore the orange wires.
IMPORTANT: the blue wire has to be connected to the left 24VAC on both controllers and the yellow wire has to be connected to the right 24VAC on both controllers.
Please contact us if you need the wire connectors shown in the picture.
瀏覽: 6200   評論: 0
更新時間 2020-02-28 07:49:20 UTC
瀏覽: 6218   評論: 3
Netro now supports Spanish, Italian, French and German for Amazon Alexa
更新時間 2020-03-16 02:40:52 UTC
Great news! We now support Spanish, Italian, French and German for Amazon Alexa voice control. Please find the new skill "NetroHome" in your Alexa app and link your Netro account.
In case you experience difficulties in using the NetroHome skill, please write to support@netrohome.com or contact us in the Netro app.
瀏覽: 26302   評論: 7
Fertilization program
Andrea Merito
更新時間 2020-04-27 14:30:47 UTC
Best.
Andrea
瀏覽: 5424   評論: 1
alnavasa
更新時間 2020-05-08 20:36:44 UTC
Start ar 21:00 end at 3am
瀏覽: 5550   評論: 0
Server upgrade scheduled on May 16th between 8:30PM and 9:00PM (Pacific Time)
更新時間 2020-05-17 03:23:28 UTC
To all Netro customers:
Due to rapid increase of active devices connected to the Netro cloud server, we are going to upgrade our server on May 16th Saturday night from 8:30PM to 9:00PM (Pacific Time). During that time frame, all cloud service will be temporarily unavailable but your watering schedules will run normally. If you have a smart watering controller, the light on the unit will blink fast.
瀏覽: 6816   評論: 0
Netro is live on IFTTT
更新時間 2020-06-07 09:01:11 UTC
瀏覽: 7321   評論: 4
