A single rain day
Rob Nelson
更新時間 2023-07-15 11:22:50 UTC
瀏覽: 4482   評論: 1
Brian Brun
更新時間 2023-08-02 01:14:30 UTC
瀏覽: 4506   評論: 1
Please issue a good manual.
Mark Menzhausen
更新時間 2023-08-27 15:04:55 UTC
瀏覽: 5089   評論: 1
Irrigreen sprinklers
更新時間 2023-09-09 08:34:33 UTC
Combining with the whisperers
https://irrigreen.com/
瀏覽: 4707   評論: 0
Alexa Skill
Louise Brinkman
更新時間 2023-10-13 01:00:17 UTC
瀏覽: 4877   評論: 3
更新時間 2023-11-07 06:10:16 UTC
瀏覽: 5244   評論: 0
Good results
R C
更新時間 2023-10-24 18:55:29 UTC
瀏覽: 6096   評論: 2
更新時間 2023-11-07 13:27:20 UTC
瀏覽: 37398   評論: 1
Thresholds
Shady Trails
更新時間 2023-12-23 16:16:15 UTC
瀏覽: 4905   評論: 3
Richard
更新時間 2024-01-07 22:48:08 UTC
UPDATE 8/1/2024
UPDATE: 5/1/2024
UPDATE: 4/1/2024
ORIGINAL:
瀏覽: 5232   評論: 11
更新時間 2024-09-19 03:30:21 UTC
瀏覽: 20760   評論: 3
Whisperer availability
更新時間 2025-03-16 18:50:01 UTC
瀏覽: 2672   評論: 1
Translation Issue - ITALIAN
Gabriele Gianello
更新時間 2019-07-03 05:18:10 UTC
Hi! I’m excited about Netro App and I’d love to contribute opening a support ticket for a double check of translations.
There’s a lot of minors but one is always in evidence: the names of the DAYS OF THE WEEK (please see the attached image) .
The right translation is:
SUNDAY : DOMENICA
MONDAY: LUNEDÌ
TUESDAY: MARTEDÌ
WEDNESDAY: MERCOLEDÌ
THURSDAY: GIOVEDÌ
FRIDAY: VENERDÌ
SATURDAY: SABATO
THE FIRST day of the week in Italy is always settend Monday
瀏覽: 7082   評論: 1
更新時間 2018-09-12 07:54:55 UTC
Resources:
瀏覽: 440035   評論: 95
更新時間 2022-04-24 01:45:07 UTC
瀏覽: 9465   評論: 1
How to Water Trees and Shrubs
更新時間 2018-06-04 10:07:08 UTC
1.How to Water Shrubs
2.How to Water Trees
Don't wait for the plants to tell you with wilting and leaves dropping off. Then youll just be watering to keep the plants roots alive so it may possible come back later. Inspect the soil. Dig around with your hands, soil probe, garden trowel, or shovel. Youll be able to tell quickly how far down you are actually watering.
Resources
瀏覽: 10558   評論: 3
更新時間 2018-06-04 10:03:46 UTC
References
瀏覽: 10189   評論: 0
更新時間 2023-11-07 06:09:05 UTC
Then you should put Sprite in "paused" mode just in case some one (for example the kids) accidentally starts a manually run from the app. To put Sprite in "paused" mode, you can go to the Home page->"Enabled".
瀏覽: 9460   評論: 1
Customization->set rain/temperature/wind threshold to skip watering
更新時間 2018-10-13 06:19:08 UTC
Netro automatically creates dynamic watering schedules according to local weather, so if you turn on the smart zone feature for your zone, season adjustment will be made with smart watering schedules according to weather.
There are different types of weather restrictions: rain, temperature and wind.
By default, If you turn on the smart zone feature, Netro will skip the schedules (including manual schedules from user programs) when there is a chance of significant rain(>0.2inch).
The default threshold to skip watering when temperature is too low is 0 Celsius degree (32 Fahrenheit) for all the Netro controllers.
You can now customize rain, temperature and wind threshold through Settings->Preferences.
瀏覽: 7865   評論: 0
更新時間 2023-06-09 06:07:25 UTC
2.Smart watering: Level basic
3.Smart-zone feature disabled
瀏覽: 16277   評論: 12
