Interface language
Bayoule Bayoule
更新時間 2022-05-11 19:31:03 UTC
Bayoule
瀏覽: 6806   回覆: 1
更新時間 2022-05-11 19:37:04 UTC
瀏覽: 7123   回覆: 1
Netro not connecting
hawkshah
更新時間 2022-05-12 02:02:39 UTC
I have switched internet providers and now Netro won’t connect to att modem.  I have run through setup many times
瀏覽: 6343   回覆: 1
stelio
更新時間 2022-05-13 00:33:14 UTC
Netro working fine last summer , I can seem
To get it to stay online . I reset the Netro and it work fine for the first 10 min … then it logs off and leave on zone open . I don’t know what to do ,To keep it online ?
瀏覽: 6852   回覆: 1
Invalid station id WU
Richard B
更新時間 2022-05-13 00:47:24 UTC
瀏覽: 6638   回覆: 1
Invalid station WU
Bayoule Bayoule
更新時間 2022-05-13 03:51:52 UTC
JM
瀏覽: 6806   回覆: 1
How do I set on/off times?
Rikki Swin
更新時間 2022-05-13 17:37:43 UTC
How do I program the on/off time on the new software? I need to have gaps between zones for pressure to rebuild. The new software is not intuitive!!!
瀏覽: 6339   回覆: 1
Manual Run
Dick Goddard
更新時間 2022-05-13 20:53:29 UTC
Please help
瀏覽: 7030   回覆: 2
Good evening It but impossible to connect me netro tells me to make sure that the correct WIFI password is entered ... I have been trying to appear for 4 hours
GERMONT Alain
更新時間 2022-05-13 23:02:49 UTC
Good evening
瀏覽: 7147   回覆: 3
Programación
jmgrau
更新時間 2022-05-15 05:30:10 UTC
Buenos dias, como tengo que programar para que la schedule no actúe solamente funcionen los programas que yo programe.
Si programo algún programa, ahora me sale la schedule también.
瀏覽: 8462   回覆: 1
Offline since a couple of days
Daniel Torres
更新時間 2022-05-15 10:01:39 UTC
Since a couple of days my Netro is offline. I have connected to my Netro to add the wifi password again and rebooted the router 3 times but still offline.
瀏覽: 6797   回覆: 1
Sprinklers only turn for a few second
Gabriele Wiel
更新時間 2022-05-15 11:11:42 UTC
good morning
just installed his transformer burned out I had an electrician install a new transformer, now it works but the sprinklers only turn on for a few seconds, what can it be
This is a photo new transformer
瀏覽: 8547   回覆: 2
Weather .
Gianluca De Virgilio
更新時間 2022-05-15 17:39:09 UTC
Good afternoon. The Weather forecast avvailable are absolutelly not real. What can I do?
Could you help me to con figure weather underground?
瀏覽: 7065   回覆: 2
Fabrice GOUFFRAN
更新時間 2022-05-16 18:02:23 UTC
Good morning, Italy is my home, I recently started to use Netro replacing an old watering device I have used for several years, so far happy with my choice. I have one whisperer sensor device and I need 2 more but they are sold out on your online website, Amazon italy is also sold out with no forecast on new availability, where can I buy ?. Thank you.
瀏覽: 9095   回覆: 2
Restrictions do not include minute limits
Cheryl Michael
更新時間 2022-05-17 03:03:27 UTC
I cannot find a way to reduce the minutes each station is watered. All stations on Eco boost. And some water almost an hour total (in 3 sessions) on allowed watering days. Our local So Cal restrictions are 10 minutes per station! How do I restrict  this?
瀏覽: 6496   回覆: 1
Bruno
更新時間 2022-05-17 19:49:58 UTC
瀏覽: 7256   回覆: 1
Home Tab
bdcfam
更新時間 2022-05-18 04:36:33 UTC
瀏覽: 6985   回覆: 1
Text in gray
Ignacio Sánchez
更新時間 2022-05-18 11:26:32 UTC
瀏覽: 6964   回覆: 1
Pixie automatic water
Shirley Johnson
更新時間 2022-05-18 18:20:36 UTC
My pixie won’t find my Wi-Fi. I’ve rebooted my router but didn’t help.
瀏覽: 8504   回覆: 1
Emilio
更新時間 2022-05-20 17:05:31 UTC
Buenas tardes,
Pronóstico o expectativas.
瀏覽: 6595   回覆: 1
