Can't login
更新时间 2025-10-13 15:40:38 UTC
This morning we noticed that my Sprite light was flashing. I tried to get into the app and it kept saying network error. I booted the Sprite, I booted my router, and the light is no longer flashing.
But when I try to log into the app now it says network error. I logged into metrohome.com and my Sprite was able to work from naturalhome.com, but I am still not able to log in to the app. I use the same login at netrohome.com as I did with my app.
浏览: 1005   评论: 1
Whisperer availability
更新时间 2025-03-16 18:50:01 UTC
浏览: 4959   评论: 1
更新时间 2024-09-19 03:30:21 UTC
浏览: 26620   评论: 3
Richard
更新时间 2024-01-07 22:48:08 UTC
UPDATE 8/1/2024
UPDATE: 5/1/2024
UPDATE: 4/1/2024
ORIGINAL:
浏览: 7054   评论: 11
Thresholds
Shady Trails
更新时间 2023-12-23 16:16:15 UTC
浏览: 7481   评论: 3
更新时间 2023-11-07 13:27:20 UTC
浏览: 41857   评论: 1
Junk box pixie
Ray Williams
更新时间 2021-06-17 22:30:16 UTC
So Dissatisfied
浏览: 9063   评论: 1
更新时间 2023-11-07 06:10:16 UTC
浏览: 7197   评论: 0
Alexa Skill
Louise Brinkman
更新时间 2023-10-13 01:00:17 UTC
浏览: 6534   评论: 3
Irrigreen sprinklers
更新时间 2023-09-09 08:34:33 UTC
Combining with the whisperers
https://irrigreen.com/
浏览: 6387   评论: 0
Please issue a good manual.
Mark Menzhausen
更新时间 2023-08-27 15:04:55 UTC
浏览: 6630   评论: 1
Brian Brun
更新时间 2023-08-02 01:14:30 UTC
浏览: 6212   评论: 1
A single rain day
Rob Nelson
更新时间 2023-07-15 11:22:50 UTC
浏览: 6002   评论: 1
Can’t open netro app
Marcos Sanz
更新时间 2023-06-12 16:35:22 UTC
浏览: 5733   评论: 1
更新时间 2018-12-13 07:48:53 UTC
Burning Bush
Fragrant Sumac
Japanese Yew
California Lilac
Creeping Juniper
Dwarf Forsythia
Snowberry
Siberian
Carpet Cypress
浏览: 10781   评论: 1
Translation Issue - ITALIAN
Gabriele Gianello
更新时间 2019-07-03 05:18:10 UTC
Hi! I’m excited about Netro App and I’d love to contribute opening a support ticket for a double check of translations.
There’s a lot of minors but one is always in evidence: the names of the DAYS OF THE WEEK (please see the attached image) .
The right translation is:
SUNDAY : DOMENICA
MONDAY: LUNEDÌ
TUESDAY: MARTEDÌ
WEDNESDAY: MERCOLEDÌ
THURSDAY: GIOVEDÌ
FRIDAY: VENERDÌ
SATURDAY: SABATO
THE FIRST day of the week in Italy is always settend Monday
浏览: 8815   评论: 1
Emilio Maione
更新时间 2019-04-25 15:49:02 UTC
浏览: 10731   评论: 2
更新时间 2019-07-29 03:11:08 UTC
Add or delete users
 Access rights of shared users
Manager’s access rights:
Player’s access rights:
浏览: 12033   评论: 4
更新时间 2019-06-05 01:59:12 UTC
To the Netro community:
浏览: 379433   评论: 24
更新时间 2019-03-19 04:52:48 UTC
浏览: 9461   评论: 0
