Google home
Sasha Obradovic
更新时间 2021-06-18 13:56:27 UTC
浏览: 6774   回复: 2
aceking
更新时间 2021-06-18 12:41:57 UTC
浏览: 6107   回复: 2
Junk box pixie
Ray Williams
更新时间 2021-06-17 22:30:16 UTC
So Dissatisfied
浏览: 10990   评论: 1
How to turn off Smart control
Riccardo Secco
更新时间 2021-06-17 19:47:41 UTC
浏览: 6261   回复: 1
Smart zone predictions?
Sid Smith
更新时间 2021-06-17 12:12:33 UTC
浏览: 6425   回复: 1
System stuck on watering
Haris Eliades
更新时间 2021-06-17 05:07:11 UTC
浏览: 6477   回复: 2
Jen Wells
更新时间 2021-06-17 00:36:39 UTC
浏览: 6557   回复: 1
更新时间 2021-06-16 14:03:50 UTC
浏览: 6899   回复: 1
Rebekah H
更新时间 2021-06-13 19:48:23 UTC
Any ideas?
Rebekah
浏览: 6694   回复: 2
Connection issue
bridgethr
更新时间 2021-06-13 18:17:52 UTC
浏览: 6561   回复: 2
Change sensor zone?
Jeff W
更新时间 2021-06-12 14:23:07 UTC
浏览: 6344   回复: 1
Marigolds
更新时间 2021-06-10 23:51:43 UTC
What is eating my marigolds
浏览: 6460   回复: 0
Spark not watering lawn
更新时间 2021-06-09 14:26:58 UTC
浏览: 6951   回复: 1
beta tester
更新时间 2021-06-06 07:50:32 UTC
浏览: 6842   回复: 1
Schedule stopped working
更新时间 2021-06-04 20:37:36 UTC
浏览: 6869   回复: 1
Sensor inputs
更新时间 2021-06-01 11:33:16 UTC
浏览: 6736   回复: 1
Sign it
Matthew Gruen
更新时间 2021-06-01 00:50:47 UTC
浏览: 6463   回复: 1
Completely ater
更新时间 2021-05-31 20:03:22 UTC
浏览: 6737   回复: 1
Pixie displays Soil Moisture reading without any sensor
Michael Host
更新时间 2021-05-11 03:07:21 UTC
Hi.  My Pixie shows a Soil Moisture reading that changes over time, but it doesn’t have a Whisperer connected to it.  It seems to influence the watering frequency.  When I look at the watering schedule, it’s supposed to water every nine days, but instead it’s watering every three days.  Is this normal?
浏览: 6170   回复: 1
Whats the difference between Forecast and Expectation
Julio Perez
更新时间 2021-05-09 16:43:52 UTC
I was looking on the preference section and see that we can select one of this. By default come with expectation selected. Wich is better?
浏览: 6044   回复: 1
