No Answers
Charles Currie
Actualizado 2024-05-25 17:07:13 UTC
Ver: 3246   Respuesta: 1
mae winslow
Actualizado 2024-05-24 02:05:23 UTC
Ver: 3242   Respuesta: 1
2 separate systems
Roger Johnston
Actualizado 2024-05-22 19:07:12 UTC
We have a 9 zone lawn system and a seperate 4 zone garden system. The controllers are 100 yards apart. We hand 2 Netro controllers and a home network that covers the entire area. Can both controllers be operated with one same app? I’ve tried but without success….must be missing something.
Ver: 3241   Respuesta: 1
Weather Underground
LM90
Actualizado 2024-05-22 16:23:22 UTC
Hi. The app wont let me add my wundergound id number (IRIBBE4). Can you please help
Ver: 3223   Respuesta: 1
Whisper 2 problems
Phil Middleton
Actualizado 2024-05-20 09:13:29 UTC
Ver: 3402   Respuesta: 1
Compatibilità con Smartthings
Farina Vincenzo
Actualizado 2024-05-18 20:44:01 UTC
Ver: 3316   Respuesta: 1
Antonio Cordon Rodriguez
Actualizado 2024-05-08 18:57:57 UTC
Hello.
I have a wishperer sensor in my garden and the measured values, in my opinion, are not correct in the following hours when the garden is watered. I have seen this same problem on other occasions. Is it possible to check it? Thank you very much.
The figure shows an example (the garden is watered at 6am):
Ver: 3400   Respuesta: 1
No LED
Derek Barss
Actualizado 2024-05-02 04:24:35 UTC
There is no LED on my device.  I've power cycled on and off a few times and no change.
Strangely enough it shows connected to wifi but not starting water on a manual test.
Is it dead?
Ver: 3521   Respuesta: 2
Netro Pixie Z1 Connection Issues to Hub - Please Help
Nicholas Cole
Actualizado 2024-04-28 15:58:10 UTC
I have a Netro Pixie Z1 hose timer in my garden, which is about 50 feet away from its hub. I’ve been dealing with connection issues (routinely disconnecting from the app and randomly stopping watering schedules), which is strange because there are no obstructions between the timer and the hub, and it is a fairly short distance. When standing by the timer, I can clearly
see the hub in my window. I have the hub plugged into the back of my WiFi router via an Ethernet cable, so WiFi connection is not the problem. The connection between the timer and the hub is. Does anybody have any suggestions on how to fix this problem? If I can’t get the Pixie Z1 to have a stable connection, I will have to buy a regular Pixie.
- Nick
Ver: 3460   Respuesta: 1
Programs
Roberto Pirovano
Actualizado 2024-04-06 16:31:34 UTC
Ver: 3277   Respuesta: 0
Potted Pkants
Actualizado 2024-03-21 20:24:24 UTC
Wency,
Houston. Texas
Ver: 3593   Respuesta: 1
Rain delay error
David Maerzke
Actualizado 2024-02-23 20:51:22 UTC
I'm getting "Error: Rain delay 1039728 with an end date of 2024-02-27."  I want to extend the delay, but it won't let me.
Ver: 3566   Respuesta: 1
Set up with mobile phone hotspot
Paul_D
Actualizado 2024-02-20 07:56:42 UTC
Hi I am going to install a sprite controller at a property before wifi is installed.
Can I set up programs on the controller using hotspot from my phone? So it can then use the irrigation schedule in offline mode until I can connect to wifi.
Ver: 3419   Respuesta: 1
Connecting to Wi-Fi
Linda Lopez
Actualizado 2024-02-07 16:08:44 UTC
I've had Netro for 3 years I changed my wifi and I updated it my app. It worked for a couple of weeks and all of a sudden it stopped working. I can't get it to connect to the wifi. It says offline. I can't even do a manual run. Does anyone have any suggestions?
Ver: 3539   Respuesta: 1
Istruzioni
Alexxxx
Actualizado 2024-02-05 20:31:47 UTC
Dove trovo le istruzioni perla programmazione Dell app in Italiano?
Thresholds
Shady Trails
Actualizado 2023-12-23 16:16:15 UTC
Ver: 4150   Comentario: 3
Netro delivery
buggs
Actualizado 2023-12-16 23:16:36 UTC
Ver: 3590   Respuesta: 1
Spark not working
Mick Faulks
Actualizado 2023-11-26 07:04:12 UTC
Ver: 3771   Respuesta: 1
Scott Flanigan
Actualizado 2023-11-10 17:04:48 UTC
Ver: 3949   Respuesta: 2
Actualizado 2023-11-07 13:27:20 UTC
Ver: 36239   Comentario: 1
