Products
  • Photo of Netro STREAM 1
  • Photo of Netro STREAM 2
  • Photo of Netro STREAM 3
Stream, Smart Indoor Watering System
List Price:
$99.00
Price:
$69.99
You Save:
$29.01
Model:
Power Adapter:
In Stock
Shipping Policy
Quantity
Netro Stream
An automated drip irrigation system designed for the lushness of your potted plants.
Netro Stream can highly automated and remote control.
Easy Scheduling
You can create any number of time-based or volume-based watering programs from the Netro mobile app. All settings and watering schedules are stored in the Netro cloud server for easy access.
Remote Control
Stream connects to the Netro cloud service through the Wi-Fi network. You can turn on or off the water instantly from the Netro mobile app, regardless of whether you are home or traveling.
Netro Stream can irrigate multiple zones and control each zone separately.
Two-zone Setup
Stream has two water outlets in order to meet the irrigation needs of different plants. By using three-way or four-way connectors, multiple potted plants can be irrigated from each outlet.
Flow Monitoring
This smart indoor irrigator has a built-in flow monitor to keep track of the amount of water used for each zone. In case of water shortage, your mobile phone can receive a push notification.
Quick Installation
No special tool is needed to setup the system. The package comes with everything you need (including drip emitters and tubing) to build this advanced watering system in 5 minutes.
Battery Mode
Stream is equipped with a rechargeable lithium battery with high capacity, and it can work anywhere in your house for weeks (low-power mode enabled) on a single charge.
Model No.: STREAM Box Contains: – Irrigation pump, holder, power adapter and cable, tubing, connectors, drip emitters, filter, plastic plugs, instructions Technical Specifications – Dimensions: 4.5 X 4.5 X 2.4 inches – Weight: 11.6 oz / 330 g – Tubing size: 4 mm (Inner diameter) – Operating temperature: 32 to 122℉ / 0 to 50℃ – Battery: 3.7V 1800mAh – USB charging current: 600mA – WiFi: 802.11 N, 2.4Ghz Warranty – 2-year limited hardware warranty
user_manual_stream.pdf
